change batteries when low
majorkuso
Joined Aug 21, 2009
59
I want to put a solar panel setup at a cabin off the grid and have a wifi hotspot and wireless security camera running off of solar charged batteries. My goal is to have the setup change over to the charged battery if the one it is currently running on gets to a low threshold and start charging. I just can't think of the logic I would need to make it work. Has anyone done something similar?
wayneh
Joined Sep 9, 2010
18,184
Is it not possible to place the batteries in parallel, to effectively have one battery? It's less efficient to switch back and forth.
majorkuso
Joined Aug 21, 2009
59
probably so I have thought about that as well. I didn't know if there was a way to balance or switch them..
wayneh
Joined Sep 9, 2010
18,184
If they are compatible voltage-wise (same chemistry) and otherwise similar, parallel is the way to go. They'll balance themselves just as the cells in a battery pack do.
