Challenge: can you light these LED's?
xox
Joined Sep 8, 2017
936
Here's the setup. You have an unlimited number of resistors, two LED's, a single push button switch, and plenty of wire. Your task is to have one LED light up when the switch is closed and the other to be lit when the switch is opened. In other words, at any given moment exactly one of them will be lit.
Can you solve the puzzle?
Beau Schwabe
Joined Nov 7, 2019
186
With a 5V DC supply and "typical" LED's, it can be done with 3 resistors.
How about adding to the challenge in that the LED's should have relatively the same amount of current to them when they are "ON"?
Tonyr1084
Joined Sep 24, 2015
9,744
@Beau Schwabe The two lower resistors form a parallel resistance along with the lower LED in series with the 200Ω. With the switch open there would be (and I know I'm going to screw this up) 66 1/3Ω, preventing the lower LED from lighting. Even then, the top LED would be at 2.5V across its junction.
However, with the switch closed (as shown) you have a voltage divider between the two lower resistors, putting the voltage across the junction of the lower LED at 1.66 volts.
Tonyr1084
Joined Sep 24, 2015
9,744
The addition of SW1 is so someone doesn't say LED1 would be always lit and drain the battery. As for SW2 adding in LED2, watch this video.
The key is the different forward voltages. As will be demonstrated in the video, the LED(s) with the lower forward voltage will draw all the current and prevent the LED(s) with the higher Vf from lighting.
Tonyr1084
Joined Sep 24, 2015
9,744
In your initial supposition (post #1) you didn't specify whether both LED's had to be the same type or same Vf. If it is the case, where both LED's must be the same Vf then the addition of one more resistor on LED1 after the PBSW "Should" provide the same effect. However, the circuit I drew is one I've built and tested. The original intent of the video was to prove that you CAN use a single resistor on a set of parallel LED's as long as the Vf is very closely matched. However, if you mis-match LED's then the one with the lower Vf will draw all the current. IF your supply can deliver more than any single LED can handle then you run the risk of blowing out that first (lowest Vf) LED. The NEXT lowest Vf LED will then take over eating all the current till it dies. This leaves even more current available for the next victim. Like domino's they will all topple. But unlike domino's which fall at a specific rate, the failure mode of LED's will accelerate exponentially. In other words, when the first LED fails the rest will fall faster and faster.
xox
Joined Sep 8, 2017
936
Okay, well that is an interesting approach. Of course, with any of these circuits, fairly specific values for the components would likely be a requirement. It's a balancing act!
ElectricSpidey
Joined Dec 2, 2017
3,358
Remove SW1 in post #9 and the circuit will work, because the color of the LEDs was not specified.
But I have a question...
Can you make an inductor with the wire?
Tonyr1084
Joined Sep 24, 2015
9,744
My guess would be that you can accomplish the same thing without any resistors IF you use a long enough length of wire to take advantage of the wire's linear resistance. OR maybe you could use a very very fine conductor to act as a higher resistance than a heavier gauge wire.
When we're not given restrictions we can come up with all kinds of things. Have you ever used an old carbon filter from a drinking system as a resistor? I have.
xox
Joined Sep 8, 2017
936
Nice! Or like this guy, using water to replace both resistors and capacitors.
