centre tap transformer output
jody
Joined Nov 12, 2012
39
hi
im repairing my simple nicad charger that melted its current output resistor due to a bad battery pack. the transformer i believe is a 12-0-12 center tap and is full wave rectified using 2 diodes. the battery pack is 9.6v 1.3ah. the sticker on the case says output 11.6v. how do i calculate the resistor. is it done to get 11.6v@1.3a
or is it done at the batteries voltage of 9.6v @'1.3a. what im unsure about is whether the battery is charged at its rated voltage or does it have to be 2 volts above at 11.6 v.
34,828
An accepted practice is to charge nicads at C/10. Hence if the capacity is 1.3Ah, C/10 is 130mA for 10-12 hours.
So if the transformer outputs 12VAC, the rectified voltage is 16VDC. You can check this with a DVM.
If you assume a 4V drop across the resistor, then the resistance required is 4V/0.13A = 33Ω @0.5W
Use a 33Ω 1W resistor.
jody
Joined Nov 12, 2012
39
i have had the multimeter on the outer two leads of the transformer with no load and it read 24.2vac so i assume it is a 12-0-12 or have i got that bit wrong.
jody
Joined Nov 12, 2012
39
im good at blunders,clever people call it science.
i have a question about the transformer output.when i measure the voltage after the diodes so its the dc bit i get 11.6 volt. i have a 1.4ohm resistor and there is no capacitor. now when on charge the battery gets up to nearly 13v. do i assume from this the transformer max output is higher than the no load reading?
#12
Without a capacitor you're measuring an AC component that is only active in the positive half cycles. This confuses some meters and most humans. Add a capacitor, any capacitor, and remove the load to read the peak voltage on a DC meter setting. That peak voltage will be inflicted on your battery, but it's not the average voltage. The average voltage is peak minus battery voltage times something I don't remember. Do what MrChips says. He's usually top dog in this department.
30,674
Your 11.6 would be about right, the battery is also going to experience the peak which is 16v, a fully charged automotive battery is around 12.6 volts.
An automotive alternator usually charges at a mean 14.5v.
jody
Joined Nov 12, 2012
39
yes im on that track just wondering how he came up with a 12vac trans outputs 16vdc.is that with a capacitor
30,674
The peak will be 16v regardless, without a capacitor you will measure the RMS, not the peak, IOW 11.6v.
Connected to the battery it will vary depending on the inherent charge.
jody
Joined Nov 12, 2012
39
perhaps i should add that the charger has a fast charge circuit and then a trickle charge circuit.its crude in that a relay cuts the fast charge and becomes the trickle charge. at the moment i have the trickle charge at the right current but a volt too high. the feed for the trickle comes from the main feed so im guessing i havnt quite got it set to 11.6 volts max.
#12
Volts peak = 1.414 times volts RMS. RMS is what transformers are rated for. Then subtract the voltage loss in the diode or diodes.
12 x 1.414 = 16.968 volts. If one diode per leg, V out is about 16.3 volts peak...assuming your power line voltage is the same as the transformer label. 120 VAC?
To arrive at 9.6 volts and .13 amps,
16.3 - 9.6 = 6.7V
But 6..7 is the peak voltage.
You're operating at about half that on the average.
3.35V/.13A = 25.7 ohms, and we're right about where MrChips was.
jody
Joined Nov 12, 2012
39
right im getting it. yeh line voltage is same as transformer,240v here. i shall try it and see what happens.
jody
Joined Nov 12, 2012
39
one more question. the fast part of this charger is crude basically a resistor after the rectifier and then a relay to cut the fast charging at a set voltage. should the maximum current be set for a flat batteries voltage ie the discharged pack will be 8 volts so as i read it this is when it will draw most current to charge which tappers of as the battery charge level increases. i am assuming that as a nicd cell charges up it will draw less current like a lead acid cell??
jody
Joined Nov 12, 2012
39
ah just done some sums and seen that at 11.6v if the battery pack wanted it it could draw 2.9amp @11.6 volt. i guess the limit is set for the higher voltage in case of peak demand if the voltage is high.
