I hink the invertor should work even on something like 1V, not so sure about the 4066.
TheDag, here is the regulator:
Since the resistor from the output to the ADJ terminal is 240 ohms then an expensive LM117 regulator must be used because the 240 ohm resistor provides its minimum load current of 5mA.TheDag, here is the regulator:
Please translate into English.So, the circuit you built for me, fit for this way?
I was not laughing at you, instead I did not understand what you said.Wtf, you are here to laugh at me?
