CD ROM stepper Window Opener
visionofast
Joined Oct 17, 2018
106
one of my favorites in electronics is playing with scrapped stuffs...
I have recently scrapped some CD ROM driver and grabbed linear stepper motors off the box...a sort of this kind:
and I could run it with an arduino program snappy and without problem...I wondered the best usage of this part for me,designing an automatic window opener or window tilter for my room. somthing to open and close windows of a room or hall in specified timing schedule.
so, I'm looking for a good mechanical desing with 3D printer or even ready junction stuffs to put it into work.the angle of tilt for this operation dos't need to be more than 15-30 degrees.
maybe the hardest part is transforming a linear to circular movement,somthing like an idler rail or an idler joint coupled with a moving handle patch in complement,and doubt about max torque it'd be able to deliver by the way.
thanks for advice.
atferrari
Joined Jan 6, 2004
5,012
Take the pain to see what the stepper was displacing and you will have an idea of the little it could do vis-a-vis your intentions.
Working with one very similar right now, for an unusual application.
visionofast
Joined Oct 17, 2018
106
actually my window is not one of that stiff joint or dampered one,it easily can move even by a wind blow.
by the way,the peoples around are used to equip gaseous heaters in winter,lots of people die beacuse of CO propagation,
and more, lose their brain cells for lack of O2.
so ,a cheap invention like this would save lots of lives and minds here.
regards
dl324
Joined Mar 30, 2015
18,328
That's not very accurate way to describe wind strength. A motor from a CD ROM isn't going to have enough strength to get it moving. Forget it if the wind is blowing in the wrong direction.
shortbus
Joined Sep 30, 2009
10,050
Thhose linear steppers are avaible with a NEMA 17 or 23 motor. But the rest are correct, that little 'can' type motor isn't likely to work. Not only that it doesn't look like you saved the 'nut' that goes along the shaft as it turns.
Janis59
Joined Aug 21, 2017
1,894
Windows opener?? Probably use the Linux instead! :) Okay, bit more serious the window glass is not much lightweight, so the task is to apply the 10-20-40 kilograms of pure force depending on lever shoulder. I wonder if half-gram motor may exert it without of 1:10 000 sprocket divider, and even if to found it will take a day long to open or close the window. Judge own, what is the force the CD is pulled in or out.
BobTPH
Joined Jun 5, 2013
11,515
I think people are misconstruing what the TS is trying to do. He mentioned tilting and the angle of the window. I imagine a window that tilts out from the bottom. This would require much less force than lifting a sliding window. The motor might still be inadequate, but not as obviously as ridiculous as everyone seems to think.
Bob
34,812
With proper reduction gear you can do it.
A small low power motor prefers to be spinning fast. So you want to spin a screw thread.
Use a worm gear followed by more gears to reduce the speed. This gives more torque.
Did you know that you can print your own gears on a 3D printer?
