My wife's which she uses as a piano. We've had it about 14 years. Maybe it doesn't owe us anything. Managed to fix quite a few snags but a bit stuck now despite my electronics background as I just cannot find a specific Schematic. This is weird! It works perfectly well on external power yet when batteries are installed (PSU unplugged) is more spasmodic in its operation. Works OK for a while but when switched off it will not come back on. Revert to external PSU & no change. Remove batteries and wait. Reinstall external PSU (9V) Now works faultlessly again every time day after day. Need I say batteries checked - no snag with them on a test load.
Inside the unit are two PCB's with mounted components. One is the "logic board with LSI chips, flash memory etc. The other is the DC power and audio PA pcb. There are two more Paxolin boards that contain the graphited switch contacts and traces for the matrix that interrogates which button is pressed.
I can see power components but without a schematic and layout its almost impossible to figure how this part works. The power On/OFF switch is a MOMentry type with a single graphite button. You need to hold it down >2secs then release to bring up the logic display. (Or turn it off). Its part of the matrix going back on X & Y ID lines to the logic pcb. A ribbon cable connects from the logic to the power board and I assume signals the power section. (As well as routing the audio to the PA section and speakers.
Is there any bright spark out there who can take me by the hand and lead me further into figuring how this works?
I do have some photos - which might help. (Attached). In anticipation..... and grateful thanks. BerryG
