carbon sensor value and sweat sensor value clash
inky90
Joined Jul 16, 2017
14
Hi guys, so currently i'm on a project where i'm suppose to add multiple sensors together and create a form of alert through LED light up and vibration motor. As such, when any of these sensors have sense a "critical" value as defined in arduino IDE, the LED will light up accordingly and vibration motor will vibrate accordingly as well.
And as such the sensors that are used for my project are :
1) DS18B20 Temperature sensor module (with breakout)
2) DFRobot SEN0219 carbon dioxide sensor
3) Adafruit ultimate GPS sensor
4) DIY Sweat sensor
5) TCS3200 colour sensor
6) RGB LED
7) coin vibration motor
8) arduino nano
The setup for all the sensor, LED and vibration are as based on the following websites (*exclude Vcc and ground setup):
1) Temperature sensor: it has only three pins (+, - , and out), therefore Vcc to +, GND to -, and one jumper wire for output signal
2) Carbon dioxide sensor: https://www.dfrobot.com/wiki/index.php/Gravity:_Analog_Infrared_CO2_Sensor_For_Arduino_SKU:_SEN0219
3) Adafruit ultimate GPS sensor: https://learn.adafruit.com/adafruit-ultimate-gps/arduino-wiring ( tx to arduino nano d3, rx to arduino d2)
4) DIY Sweat sensor: https://hackaday.com/2016/09/21/arduino-detects-pants-on-fire/#more-223595, http://www.circuitbasics.com/arduino-ohm-meter/ (essentially it is voltage divider with the use of known and unknown resistors, in this case skin is the "unknown resistor")
5) TCS3200 colour sensor: http://howtomechatronics.com/tutorials/ ... or-sensor/
6) RGB LED: http://howtomechatronics.com/tutorials/arduino/how-to-use-a-rgb-led-with-arduino/
7) Coin vibration motor: http://tinkbox.ph/learn/tutorial/how-control-vibration-motor-using-arduino-uno/wiring-diagram
The Vcc and GND to power all components are as follows:
1) Lipo battery 7.4V, 850 mAh to pololu step down regulator 5V, 2.5A to: Colour sensor, Sweat sensor, GPS sensor, Temperature sensor, RGB LED and vibration motor
2) arduino nano 5v pin and gnd to carbon dioxide sensor
3) Lipo battery 7.4V, 850 mAh to arduino nano Vin and GND
4) usb connection to arduino nano
And the following code were used to operate all of the sensors:
Code:
/* Variables for LED */
int redPin = 9;                                             // Declare pin 9 in arduino for RGB LED
int greenPin = 10;                                          // Declare pin 10 in arduino for RGB LED
int bluePin = 11;                                           // Declare pin 11 in arduino for RGB LED
/* Variables for Motor */
const int motorPin = 13;                                    // Declare pin 13 in arduino for motor
/* Variables for Carbon Sensor */
int carbonPin = A0;                                         // declare pin 0 in arduino for Carbon Sensor
/* Variables for Temperature */
#include <OneWire.h>                                        // Include onewire.h library file
#include <DallasTemperature.h>                              // Include dallas Temperature.h library file
#define ONE_WIRE_BUS 12                                     // Declare pin 12 in Arduino
OneWire oneWire(ONE_WIRE_BUS);                              // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
DallasTemperature sensors(&oneWire);                        // Pass our oneWire reference to Dallas Temperature
/* Variables for Galvanic Skin Response Sensor */
const int gsrPin  =  A1;                                    // Declare pin A1 in arduino for GSR Sensor
int raw = 0;                                                // Make raw an integer 0
int Vin = 5;                                                // Make input voltage as an integer of 5
float Vout = 0;                                             // Make output voltage as an decimal point number of 0
float R1 = 510000;                                          // Make known resistor as an decimal point number of 510000 k ohm
float R2 = 0;                                               // Make unknonwn resistor (skin resistance) as a decimal point number of 0
float buffer = 0;                                           // Make buffer as a decimal point number of 0
float conductance = 0;                                      // Make skin conductance as a decimal point number of 0
/* Variables for GPS */
#include <Adafruit_GPS.h>                                   // include library file
#include <SoftwareSerial.h>                                 // include library file
SoftwareSerial mySerial(3, 2);                              // set up a new serial object
Adafruit_GPS GPS(&mySerial);
#define GPSECHO  false                                      // Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console, // Set to 'true' if you want to debug and listen to the raw GPS sentences.
boolean usingInterrupt = false;                             // this keeps track of whether we're using the interrupt// off by default!
void useInterrupt(boolean);                                 // Func prototype keeps Arduino 0023 happy
uint32_t timer = millis();
/* Variables for Colour Sensor */
#define S0 4                                                // Declare pin 4 in arduino for Colour sensor, S0 pin
#define S1 5                                                // Declare pin 5 in arduino for Colour sensor, S1 pin
#define S2 6                                                // Declare pin 6 in arduino for Colour sensor, S2 pin
#define S3 7                                                // Declare pin 7 in arduino for Colour sensor, S3 pin
#define sensorOut 8                                         // Declare pin 8 in arduino for Colour sensor, Out pin
int redFrequency = 0;                                       // Declare an integer value of 0 in arduino for redFrequency
int greenFrequency = 0;                                     // Declare an integer value of 0 in arduino for greenFrequency
int blueFrequency = 0;                                      // Declare an integer value of 0 in arduino for blueFrequency
void setup()                                                // Setup function will only run once, after each powerup or reset of the Arduino board, Use it to initialize variables, pin modes, start using libraries, etc
    /* Configuration of pins */
    pinMode(redPin,OUTPUT);                                 // Initialize redPin as an output
    pinMode(greenPin,OUTPUT);                               // Initialize greenPin as an output
    pinMode(bluePin,OUTPUT);                                // initialize bluePin as an output
    pinMode(motorPin,OUTPUT);                               // Initialize motorPin as an output
    pinMode (carbonPin,INPUT);                              // initialize digital pin motorPin as an input
    pinMode (gsrPin,INPUT);                                 // Initialize gsrPin as an input
    pinMode(S0, OUTPUT);                                    // Initialize S0 Pin as an input
    pinMode(S1, OUTPUT);                                    // Initialize S1 Pin as an input
    pinMode(S2, OUTPUT);                                    // Initialize S2 Pin as an input
    pinMode(S3, OUTPUT);                                    // Initialize S3 Pin as an input
    pinMode(sensorOut, INPUT);                              // Initialize SensorOutPin as an input
    /* Output frequency scaling of 20% */
    digitalWrite(S0,HIGH);                                  // Write a high value (5 volts) for S0 Pin
    digitalWrite(S1,LOW);                                   // Write a Low value (0 volts) for S1 Pin
    Serial.begin(115200);                                   // Sets the data rate at 9600 in bits per second (baud) for serial data transmission
    sensors.begin();                                        // Initiate the sensor library and join the I2C bus as a master or slave
    /* Setup for GPS sensor */
    GPS.begin(9600);                                        // 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
    GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);           // uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
    GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);              // 1 Hz update rate  // For the parsing code to work nicely and have time to sort thru the data, and print it out we don't suggest using anything higher than 1 Hz
    useInterrupt(true);                                     // the nice thing about this code is you can have a timer0 interrupt go off every 1 millisecond, and read data from the GPS for you
void loop()                                                 // Repeat function
    /* Setup for risk values which will be use for LED lightup */
    int SkinRiskValue;                                      // Make SkinRiskValue as an integer number, a value to calculate risk for temperture sensor
    int SweatRiskValue;                                     // Make SweatRiskValue as an integer number, a value to calculate risk for GSR sensor
    int LocationRiskValue;                                  // Make LocationRiskValue as an integer number, a value to calculate risk for GPS sensor
    int ColourRiskValue;                                    // Make ColourRiskValue as an integer number, a value to calculate risk for Colour sensor
    int CarbonRiskValue;                                    // Make CarbonRiskValue as an integer number, a value to calculate risk for Colour sensor
    int y;                                                  // Make y as an integer number, a value to sum all risk values for all sensors, and allow for mapping
    char* myStrings[]={"No colour  ", "Red detected  ", "Green detected  ", "Blue detected  ","Purple detected  ","Orange detected  ","Yellow detected  "}; // intialize words as characters
    int x;                                                  // Make x as an integer number, a value to indicate the chosen colour
    /* Setup for Carbon Dioxide */
    int carbonValue = analogRead (carbonPin);               // Make carbonValue as an integer number, a value that reads value from the specified analog pin
    float voltage = carbonValue*(5000/1024.0);              // Make voltage as an decimal point number, a value that depends on carbonValue which is then multiply by 5000 & divide by 1024.00
    int voltage_diference=voltage-400;                      // Make voltage_diference as an integer number, a value that depends voltage minus 400
    float concentration = voltage_diference * 50.0/16.0;    // Make concentration as an decimal point number, a value that depends on voltage_diference multiply by 50/16
    /* Setup for GSR Sensor */
    raw = analogRead(gsrPin);                               // Reads the value from the specified analog pin, GSR, and intialize it as raw
    buffer = raw * Vin;                                     // Intialize buffer as raw value multiply as voltage input value
    Vout = (buffer)/1024.0;                                 // Intialize output voltage as buffer divided by value of 1024
    buffer = (Vin/Vout) -1;                                 // Intialize buffer as input divided by output voltage, multiply by negative 1
    R2 = R1 * buffer;                                       // Intialize unknonwn resistor as known resistor multiply by buffer value
    conductance = (1/R2)*1000000;                           // intialize conductance value as 1 divided by unknown resistance value, multiply by 1000000 (condutance is calculated as microsiemens)
    /* Setup for Temperature */
    sensors.requestTemperatures();                          // Send the command to get temperatures
    /* Setup for GPS */
    if (GPS.newNMEAreceived())                              // If a sentence is received, we can check the checksum, parse it...
        if (!GPS.parse(GPS.lastNMEA()))                     // This sets the newNMEAreceived() flag to false
          return;                                           // We can fail to parse a sentence in which case we should just wait for another
    if (timer > millis())  timer = millis();                // If millis() or timer wraps around, we'll just reset it
    if (millis() - timer > 4000)                            // Approximately every 4 seconds or so, print out the current stats
        timer = millis();                                   // Reset the timer
        /* Display values at serial monitor */
        Serial.print("Temperature: ");                      // Print a message, do not move to the next line
        Serial.print(sensors.getTempCByIndex(0));           // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
        Serial.print(" Degree");                            // Print a message, do not move to the next line
        Serial.print("  |  ");                              // Print a message, do not move to the next line
        Serial.print("Carbon Dioxide is: ");                // Print a message, do not move to the next line
        Serial.print(concentration);                        // Print a value, do not move to the next line
        Serial.print(" ppm   ");                            // Print a message, do not move to the next line
        Serial.print("voltage: ");                          // Print a message, do not move to the next line
        Serial.print(voltage);                              // Print a value, do not move to the next line
        Serial.print("  mv");                               // Print a message, do not move to the next line
        Serial.print("Conductance: ");                      // Print a message, do not move to the next line
        Serial.print (conductance, 6);                      // Print a value, do not move to the next line
        Serial.print("  uS   ");                            // Print a message, move to the next line
        Serial.print("Resistance: ");                       // Print a message, do not move to the next line
        Serial.print (R2, 4);                               // Print a value, do not move to the next line
        Serial.print("  Ohm");                              // Print a message, move to the next line
        digitalWrite(S2,LOW);                               // Write a low value (0 volts) for S2 Pin
        digitalWrite(S3,LOW);                               // Write a low value (0 volts) for S3 Pin
        redFrequency = pulseIn(sensorOut, LOW);             // pulseIn() waits for the pin to go low, starts timing, then waits for the pin to go high and stops timing. Returns the length of the pulse in microseconds
        Serial.print("Red = ");                             // Print a message, do not move to the next line
        Serial.print(redFrequency);                         // Print a value, do not move to the next line
        digitalWrite(S2,HIGH);                              // Write a high value (5 volts) for S2 Pin
        digitalWrite(S3,HIGH);                              // Write a high value (5 volts) for S3 Pin
        greenFrequency = pulseIn(sensorOut, LOW);           // pulseIn() waits for the pin to go low, starts timing, then waits for the pin to go high and stops timing. Returns the length of the pulse in microseconds
        Serial.print(" Green = ");                          // Print a message, do not move to the next line
        Serial.print(greenFrequency);                       // Print a value, do not move to the next line
        blueFrequency = pulseIn(sensorOut, LOW);            // pulseIn() waits for the pin to go low, starts timing, then waits for the pin to go high and stops timing. Returns the length of the pulse in microseconds
        Serial.print(" Blue = ");                           // Print a message, do not move to the next line
        Serial.print(blueFrequency);                        // Print a value, do not move to the next line
        Serial.print("  ");                                 // Print a message, do not move to the next line
        float skin_temp = sensors.getTempCByIndex(0);       // Make skin_temp as a decimal point number, where values is obtain through sensors.getTempCByIndex(0)
        /* if else conditions for Colour */
        if(redFrequency > 20 && redFrequency < 45 &&  greenFrequency > 55 && greenFrequency < 80 && blueFrequency > 35 && blueFrequency < 60 && greenFrequency > blueFrequency &&  blueFrequency > redFrequency) // define for red
            ColourRiskValue = 3;                            // Value of ColourRiskValue is equal to 3 (high risk)
            x = 1;                                          // Value of x is equal to 1 (red colour detected)
        else if(redFrequency > 15 && redFrequency < 30 &&  greenFrequency > 40 && greenFrequency < 65 && blueFrequency > 30 && blueFrequency < 55 && greenFrequency > redFrequency &&  blueFrequency > redFrequency) // define for orange
            x = 5;                                            // Value of x is equal to 5 (orange colour detected)
        else if(redFrequency > 35 && redFrequency < 55 &&  greenFrequency > 15 && greenFrequency < 50 && blueFrequency > 30 && blueFrequency < 55 && redFrequency > greenFrequency /*&&  redFrequency > blueFrequency*/) // define for green
            x = 2;                                            // Value of x is equal to 2 (green colour detected)
        else if(redFrequency > 45 && redFrequency < 75 &&  greenFrequency > 25 && greenFrequency < 45 && blueFrequency > 10 && blueFrequency < 30 && redFrequency > greenFrequency &&  greenFrequency > blueFrequency) // define for blue
            x = 3;                                            // Value of x is equal to 3 (blue colour detected)
        else if(redFrequency > 25 && redFrequency < 45 &&  greenFrequency > 40 && greenFrequency < 65 && blueFrequency > 15 && blueFrequency < 35 && greenFrequency > blueFrequency &&  greenFrequency > redFrequency) // define for purple
            x = 4;                                            // Value of x is equal to 4 (purple colour detected)
        else if(redFrequency > 10 && redFrequency < 25 &&  greenFrequency > 15 && greenFrequency < 30 && blueFrequency > 15 && blueFrequency < 40 && blueFrequency > redFrequency/* && greenFrequency > redFrequency*/) // define for yellow
            x = 6;                                            // Value of x is equal to 6 (yellow colour detected)
        else                                                // If no condition is met as mentioned previously
            ColourRiskValue = 0;                              // Value of ColourRiskValue is equal to 0 (no risk)
            x=0;                                              // Value of x is equal to 0 (no colour detected)
        Serial.print("Colour: ");                           // Print a message, do not move to the next line
        Serial.print(myStrings[x]);                         // Print a value based on char that was initalize previously, do not move to the next line
        Serial.print(" Location (Latitude, Longtitude): "); // Print a message, do not move to the next line
        Serial.print(GPS.latitudeDegrees, 6);               // Print a value, do not move to the next line
        Serial.print(", ");                                 // Print a message, do not move to the next lin
        Serial.println(GPS.longitudeDegrees, 6);            // Print a value, move to the next line
        Serial.println("");                                 // Print a message, move to the next line
        /* if conditions for Temperature */
        if (skin_temp < 25.5)                               // If condition is met
             SkinRiskValue = 0;                             // Value of SkinRiskValue is equal to 0 (no risk)
        if (skin_temp > 25.5 && skin_temp < 26)             // If condition is met
             SkinRiskValue = 1;                             // Value of SkinRiskValue is equal to 1 (low risk)
        if (skin_temp > 26.00 && skin_temp < 26.5)          // If condition is met
            SkinRiskValue = 2;                              // Value of SkinRiskValue is equal to 2 (medium risk)
        if (skin_temp > 26.50)                              // If condition is met
            SkinRiskValue = 3;                              // Value of SkinRiskValue is equal to 3 (high risk)
        /* if conditions for Carbon dioxide */
        if (concentration < 900)                            // If condition is met
            CarbonRiskValue = 0;                            // Value of CarbonRiskValue is equal to 0 (no risk)
        if (concentration > 900 && concentration < 1500)    // If condition is met
           CarbonRiskValue = 1;                             // Value of CarbonRiskValue is equal to 1 (lowrisk)
        if (concentration > 1500 && concentration < 2000)   // If condition is met
            CarbonRiskValue = 2;                            // Value of CarbonRiskValue is equal to 2 (medium risk)
        if (concentration > 2000)                           // If condition is met
           CarbonRiskValue = 3;                             // Value of CarbonRiskValue is equal to 3 (high risk)
        /* if conditions for Sweat */
        if (conductance < 5)                                // If condition is met
            SweatRiskValue = 0;                             // Value of SweatRiskValue is equal to 0 (no risk)
        if (conductance > 1 && conductance < 5)             // If condition is met
            SweatRiskValue = 1;                             // Value of SweatRiskValue is equal to 1 (low risk)
        if (conductance > 5 && conductance < 10)            // If condition is met
           SweatRiskValue = 2;                              // Value of SweatRiskValue is equal to 2 (medium risk)
        if (conductance > 10)                               // If condition is met
            SweatRiskValue = 3;                             // Value of SweatRiskValue is equal to 3 (high risk)
        /* if conditions for GPS */
        if (GPS.latitudeDegrees > 1.441700 && GPS.latitudeDegrees < 1.442000 || GPS.latitudeDegrees > 1.443600 && GPS.latitudeDegrees < 1.443900)                     // If condition is met
            if (GPS.longitudeDegrees > 103.806400 && GPS.longitudeDegrees < 103.808700)              // If condition is met
                LocationRiskValue = 1;                                                               // Value of LocationRiskValue is equal to 1 (low risk)
        else if (GPS.longitudeDegrees > 103.806400 && GPS.longitudeDegrees < 103.806760 || GPS.longitudeDegrees > 103.808425 && GPS.longitudeDegrees < 103.808700)    // If condition is met
            if (GPS.latitudeDegrees > 1.441700 && GPS.latitudeDegrees < 1.443900)                   // If condition is met
        else if (GPS.latitudeDegrees > 1.442000 && GPS.latitudeDegrees < 1.442516 || GPS.latitudeDegrees > 1.443288 && GPS.latitudeDegrees < 1.443600)                // If condition is met
            if (GPS.longitudeDegrees > 103.80676 && GPS.longitudeDegrees < 103.808425)              // If condition is met
                LocationRiskValue = 2;                                                              // Value of LocationRiskValue is equal to 2 (medium risk)
        else if (GPS.longitudeDegrees > 103.806760 && GPS.longitudeDegrees < 103.807276 || GPS.longitudeDegrees > 103.807909 && GPS.longitudeDegrees < 103.808425)    // If condition is met
            if (GPS.latitudeDegrees > 1.442000 && GPS.latitudeDegrees < 1.443600)                   // If condition is met
        else if (GPS.latitudeDegrees > 1.442516 && GPS.latitudeDegrees < 1.443288 && GPS.longitudeDegrees > 103.807276 && GPS.longitudeDegrees < 103.807909)          // If condition is met
            LocationRiskValue = 3;        // Value of LocationRiskValue is equal to 3 (high risk)
            LocationRiskValue = 0;        // Value of LocationRiskValue is equal to 0 (no risk)
        /* Setup for fading LED and summation of values */
        int TotalRiskValue = SkinRiskValue + SweatRiskValue + ColourRiskValue + LocationRiskValue + CarbonRiskValue;    // Make total as a integer, where values is depending of all the risks combine (values of sensors)
        y = map(TotalRiskValue, 1, 15, 0, 255);              // Make y as a value that depends on the value of total, in which is map linearly to 0 to 255
        int i = 255 - y;                                     // Make i as an integer, where values is 255 minus off the value of y
        Serial.print("LED Colour Mapping (R,G,B): ");        // Print a message, do not move to the next line
        //Serial.print(y);                                   // ********Print a value, do not move to the next line
        Serial.print("255 ");                                // ********Print a message, do not move to the next line
        Serial.print(" , ");                                 // Print a message, do not move to the next line
        Serial.print(i);                                     // Print a value, move to the next line
        Serial.print(" , 0 ");                               // Print a message, do not move to the next line
        Serial.print("  total risk: ");                      // Print a message, do not move to the next line
        Serial.print(TotalRiskValue);                        // Print a value, do not move to the next line
        Serial.print("  skin: ");                            // Print a message, do not move to the next line
        Serial.print(SkinRiskValue);                         // Print a value, do not move to the next line
        Serial.print("  Carbon: ");                          // Print a message, do not move to the next line
        Serial.print(CarbonRiskValue);                       // Print a value, do not move to the next line
        Serial.print("  sweat:  ");                          // Print a message, do not move to the next line
        Serial.print(SweatRiskValue);                        // Print a value, do not move to the next line
        Serial.print("  color risk: ");                      // Print a message, do not move to the next line
        Serial.print(ColourRiskValue);                       // Print a value, do not move to the next line
        Serial.print("  location risk:  ");                  // Print a message, do not move to the next line
        Serial.println(LocationRiskValue);                   // Print a value, move to the next line
        Serial.println(" ");                                 // Print a message, move to the next line
        delay(1000);
        if (TotalRiskValue > 0 && TotalRiskValue <16)        // If condition is met, where value of total is between 1 to 15, else do not display colour when TotalRiskValue is 0
            setColor(255, i, 0);                             //******** Display LED colours based on the value of i and y, blue value is set to zero
            if (TotalRiskValue > 10)                         // If condition is met, where value is more than 10 (high risk)
                digitalWrite(motorPin, HIGH);                // Write a HIGH value to a digital pin
                delay(500);                                  // Delay action for 500 milliseconds
                digitalWrite(motorPin, LOW);                 // Write a LOW value to a digital pin
            else if (TotalRiskValue > 5  && TotalRiskValue < 11)// If condition is met, where value is between 6 and 10 (medium risk)
                delay(1000);                                 // Delay action for 1000 milliseconds
            setColor(0,0,0);                                 // Turn off LED colours
        else                                                 // If condition is not met, where values are not more than 1
            setColor(0, 0, 0);                               // Turn off LED colours
SIGNAL(TIMER0_COMPA_vect)                                    // Interrupt is called once a millisecond, looks for any new GPS data, and stores it
    char c = GPS.read();                                     // Make C a character, reads incoming serial data
    #ifdef UDR0                                              // If you want to debug, this is a good time to do it!
    if (GPSECHO)                                             // If condition
    if (c) UDR0 = c;                                         // Writing direct to UDR0 is much much faster than Serial.print but only one character can be written at a time.
    #endif                                                   // Specifies the end of a conditional directive
void useInterrupt(boolean v)
    if (v)                                                   // Timer0 is already used for millis() - we'll just interrupt somewhere in the middle and call the "Compare A" function above
        OCR0A = 0xAF;
        TIMSK0 |= _BV(OCIE0A);
        usingInterrupt = true;
    else                                                     // Do not call the interrupt function COMPA anymore
        TIMSK0 &= ~_BV(OCIE0A);
void setColor(int redValue, int greenValue, int blueValue)  // setColor(redValue, greenValue, blueValue)
    analogWrite(redPin, redValue);                          // Writes an analog value (PWM wave) to a pin, analogWrite(pin port, value set)
    analogWrite(greenPin, greenValue);                      // Writes an analog value (PWM wave) to a pin, analogWrite(pin port, value set)
    analogWrite(bluePin, blueValue);                        // Writes an analog value (PWM wave) to a pin, analogWrite(pin port, value set)
image attached shows the connections through the breadboard.
**note: setup and coding works as intended.
so basically with the setup and coding inplace, this is where problem comes about. when i power up the devices as seen from the listed connection mentioned earlier. and then i open up the serial monitor, i notice that when i touch the DIY sweat sensor (which is the red and black wire as seen in the picture) the value of sweat increase, but however, the carbon dioxide value ALSO increase together with the sweat sensor. this can be seen in the attached image. This happens also when i remove my hand from the wires. the carbon dioxide value also decrease.
This do not happens all the time. sometimes i would try restarting arduino IDE and replug the usb connection and lipo battery. and then it goes back to normal, where the touch of sweat sensor do not affect the carbon dioxide sensor value. but after it becomes normal, i would then "activate" all of the sensors, then the value of sweat sensor AGAIN affect the carbon sensor value.
so can anyone tell me what is this happening? i dun really understand because voltage supply to carbon sensor and sweat sensor are different, and the code had also define carbon pin and sweat pin differently, where carbon is given as A0 sweat (GSR) is given as A1 in arduino IDE. My friend actually pinpointed that this could be due to voltage glitch which im not really sure what he meant.
IN addition, can anyone help to resolve this issue?
WBahn
Joined Mar 31, 2012
32,823
Have you looked at the carbon dioxide sensor output directly as you touch the sweat sensor? That would narrow things down as to whether the program is causing the interaction or just reporting it.
inky90
Joined Jul 16, 2017
14
Hi WBahn, if u are referring to the values output by the carbon sensor through the serial monitor, then yes. if u look at my post then u would notice an image attached.
Note: the output by the carbon sensor alone when brought to different environment is able to have different values. for example: outside environment it display output of 1000 on average while indoor is on average 1000 plus to 2000 plus
different types of setup on the breadboard has been done as well. as in i have taken out vibration motor and LED to try to figure out if the LED and vibration motor could be the cause. but even though i taken out the setup for vibration and LED or even if i implement both components, The values of sweat would STILL clash with carbon sensor values.
inky90
Joined Jul 16, 2017
14
This is an example of normal values when sweat sensor is touch. it can be notice that the carbon sensor values do not clash with sweat sensor, where their values are independent (after several attempts of resetting and restarting of arduino IDE and microcontroller)
WBahn
Joined Mar 31, 2012
32,823
If I understand your image, what it is showing are values calculated by your program and then displayed. What if there is a bug in the program, such as memory that is improperly allocated so that, at times, writing to a variable that is supposed to be used for the sweat sensor is overwriting some memory location that is also being used for the carbon dioxide sensor.
I'm recommending that you look at the output of the sensors directly -- before they get into the microcontroller at all -- to see if the behavior exists there, or only within the microcontroller.
The fact that the behavior comes and goes with resetting the microcontroller leads me to suspect that the problem is a bug in the code. However, I'm not going to sift through several hundreds of lines of code -- and you shouldn't either until you take steps to pin down where the phenomenon does and does not exist within your processing chain.
One way is to look at the sensor outputs directly. Another would be to rig up a fake sensor that always reports the same data (or at least data that you know what it is) to the microcontroller. If the problem persists, then you know that it is within the microcontroller. If it goes away, then you can suspect something with the sensor or perhaps the communication link to it.
Yet another possibility, if some of the sensors use the same communication protocol, is to swap them around and see if the problem follows the physical sensor or not.
You might also examine the memory map that your code is using.
You might strip out as much of your code as possible while still exhibiting the bad behavior. That will let you focus on where the problem might lie and ignore places where it can't. If, in doing this, the problem goes away when you strip out some part of the code, you have a smoking gun.
The fact that you have so much code while dealing with a problem like this leads me to suspect that you did not take an incrementalist approach to your code development -- something that is all too common in the rush to "get things done". The first thing you probably should have done was written just barely enough code to display the raw sensor data on the screen and nothing more. It's quite possible that very early on this problem would have made itself evident and you could have tracked it down then. If it was introduced by later code, then incrementally building up and testing the code would have revealed the problem soon after the problem was introduced. It's not at all too late to still do that. Write fresh code that just does the most basic, brute force stuff. Then flesh it out as you go. Being guided by the code you already have should make this a very fast process, perhaps the work of just a couple hours time.
Raymond Genovese
Joined Mar 5, 2016
1,653
I agree with advice that you have already received, especially the "divide and conquer" approach. In this regard, if you strip down to only the two analog out sensors, and after having examined their behavior unconnected as suggested, AND you still get the problem, it sounds like cross-talk between the analog input channels.
This is not at all that uncommon, see this search for example. If you follow those threads, you can see the various ways the problem shows up and various solutions - sometimes as easy as a cap on Vref, sometimes solving sensor impedance issues, sometimes a delay between the two device reads - lots of possible reasons and solutions (see this design note on the general issue).
Again, I'm not saying it is the problem, I'm saying that it could be - especially if you eliminate the other potential problems as already mentioned.
