Ok guys, I'm new here, and have seen a post here going over a memory wire connection on a car radio...
I have a slightly different question, regarding how to power the memory circuit, and have a few related questions id like an answer to, that will be listed below. But before I ask my questions, I have uploaded a picture of my setup, i made completely by hand and wired the car stereo and speakers into, and will explain below how the power is wired in...
Current setup is 1 positive and 1 negative wire going in the boombox case which will always remain the same, that gets split into 2 positive wires, one going to memory board, the other going to a power switch which then is used to turn screen off and on if I need total darkness for some reason, and the power, as is standard, then returns to the negative wire and so on...
Question 1... is the memory circuit a separate circuits from the power circuit.
Question 2... could I hook a couple of 12v(or 12v combined) (similar to C or D batteries in size) rechargeable batteries inside, to run the memory circuit.
Question 3... if you can use rechargable batteries, how would I charge them.
If you need more information let me know, but be advised that I do not check my email for new notifications every day, so i may respond quickly, or I may not... also, note that my radio in the picture isn't plugged in at the moment, so no pretty colorful lights are visible...
