Hello guys
I want to ask you something about capacitors! I know very well that if I will join 2 capacitors in series, it will cause the reduction of the capacitance according to the formula:
C=C1*C2/C1+C2 (for 2 capacitors) and 1/C=1/C1+1/C2+1/C3+......+1/Can (for more capacitors)
Especially for the parallel provision* with following formula:
C=C1+C2+C3+......+Cn
Say, we charge each of capacitor provisions (parallel or series) with 12V AC (because the capacitors acts like open circuit if being charged with DC voltage)! What will be the result on that what happen with voltage/current? They will be increased or decreased? Someone said me that if I join 2 capacitors 6800uF in parallel provision and charge them with 12V/1A, then the current will be increased when the voltage is the same, 12V! Is this wrong? If it is not then could I join some capacitors so as to increase the current of a source, that produce 12V/1A AC, to 12V/7A AC? I just asked I have not idea what exactly happens! I just want to make a power supply that produce 12V/7A! What can I do in case if the theory of capacitors is wrong?
*(I don't know if I'm correct with word "provision"! If I said the word with false significance please correct me!)
