U Thread Starter uppi_777 Joined Feb 26, 2018 23 Nov 24, 2020 #1 I am looking for a capacitor with the following requirements. I looked in may distributor websites but did not find it 1µF/25V 10% 402 Pkg X7R can anyone help to find me a similar or same kind of capacitor
MrChips Joined Oct 2, 2009 22,476 Nov 24, 2020 #2 Your problem is the operating voltage (25V) vs package (0402). You can either reduce the voltage or increase the package size (0603 for example).
U Thread Starter uppi_777 Joined Feb 26, 2018 23 Nov 24, 2020 #3 I cannot change my operating voltage and also package size. because its already in layout state
bertus Joined Apr 5, 2008 21,025 Nov 24, 2020 #5 Hello, X7R is not available in that size and values. X5R and X6S are available here: https://www.digikey.com/en/products...RMOxVHcABWgDFXd0MAVUF+NgB5FABZHDQsAFdeHHExMSA Bertus
U Thread Starter uppi_777 Joined Feb 26, 2018 23 Nov 24, 2020 #7 still not satisfied as i am looking for the similar temp range from X7R. Thanks for your inputs
bertus Joined Apr 5, 2008 21,025 Nov 24, 2020 #8 Hello, Why do you need a high temperature of 125 °C ? http://www.iequalscdvdt.com/Ceramic.html Bertus
bertus Joined Apr 5, 2008 21,025 Nov 24, 2020 #10 Hello, For X7R the minimum size is 0603: https://www.digikey.com/en/products...BVHi5GAHlkAFlsVEwAVw5scoBaFX8oTjG8+ScipKFBQSA With 0402 you will not find any in X7R. Bertus
A andrewmm Joined Feb 25, 2011 878 Nov 24, 2020 #11 We've all done it you need to re spin your board then, Sorry , the rules of physics say "at the moment", an 0402 at that voltage and capacitance does not exist in X7
U Thread Starter uppi_777 Joined Feb 26, 2018 23 Nov 24, 2020 #12 Could you please let me know which is the nearest alternative which i can use
A andrewmm Joined Feb 25, 2011 878 Nov 24, 2020 #13 just look on the sites such as digikey , the biggest 0402, 25V X7R I can see is 220 nf
MrChips Joined Oct 2, 2009 22,476 Nov 24, 2020 #14 Here are your constraints: 1 - value = 1μF 2 - voltage = 25V 3 - temperature range = X7R 4 - package = 0402 5 - PCB layout Change any one of those and you have a fit. Edit: Before someone jumps on me, I know, changing 4 and 5 are two changes.
bertus Joined Apr 5, 2008 21,025 Nov 24, 2020 #15 just look on the sites such as digikey , the highest voltage for 0402, X7R , 1 μF, I can see is 6.3 V
A andrewmm Joined Feb 25, 2011 878 Nov 24, 2020 #16 bertus said: just look on the sites such as digikey , the highest voltage for 0402, X7R , 1 μF, I can see is 6.3 V Click to expand... How about 4 of them in series, a sort of supper tomb stone affare on the board.
