Capacitor question
Adam Hill
Joined Jan 26, 2016
7
I am working with a Small 110v flux core welder. It came set up as an AC machine. Flux core wants dc current. The secondary output is around 26 volts with, I think, 125 amps max. So far I have taken the secondary into a bridge rectifier rated at 1600v and 200a, from there it goes to a 89000mfd cap, and finally out to the ground and lead. With this set up there is still a charge left in the cap after weld is complete. I was thinking of adding a resistor across the cap to discharge it after each weld. Will this work, or would it cause a failure somewhere? If it would work, any idea what size resistor would be best?
30,663
You can wire a discharge resistor across the cap, but it is generally considered a large series choke/inductor is more common to see that a cap.
Lestraveled
Joined May 19, 2014
1,946
Yes, it will work, and is common practice in welders. A 10 watt, 20 ohm resistor will discharge the cap to 6 volts in about 6 seconds.
Adam Hill
Joined Jan 26, 2016
7
after a weld if the wire sticking out the end of the gun touches the grounded work it will throw a rather large surprising spark and bond the wire to the work, usually in a spot you did not intend to weld. I would imagine this discharge going through my hand would be most unpleasent.
18,105
I said "little" instead of "no", because under unusual circumstances (sweaty hands, large metal surface to grip), you might feel it. You certainly feel a 9V battery on your tongue but it's hard to replicate that outside of your mouth.
SLK001
Joined Nov 29, 2011
1,549
You weld without gloves? Not very smart (but I have to admit, that I will MIG weld in a T-shirt and a glove only on the non-gun hand). I also admit to knowing about the "after-spark" that you are talking about. Better technique is probably a more cost effective approach to your sticking problem. As a welder, both stick and MIG, you get used to being shocked. Sweat will provide a conduction path thru your gloves and clothes as will welding in the rain or in wet conditions. It isn't "most unpleasent" as you imagined, but more like a fly or gnat inside your helmet - just irritating, but doing no real harm. The voltage is just too low for any major concern.
shortbus
Joined Sep 30, 2009
10,050
I have a pro level Miller welder and it does the after spark too. Always put it down to inductance from the cable liner inductance being discharged. Without tearing into the welder, I'm pretty sure the on-off switching circuit is between the smoothing cap and the output to the stinger. If so a discharge resistor on the filter/smoothing won't stop the after spark. Every mig/wire feed welder I've ever used since ~1966 does the after spark thing.
hp1729
Joined Nov 23, 2015
2,304
Do you need the capacitor?
Adam Hill
Joined Jan 26, 2016
7
Well... I'm not sure that I do need the capacitor. I got the inspiration from watching several people on the internet do this mod. They put a cap in, so like a sheep I followed suit and put a cap in. The theory is it will make the weld "smoother." Then again the ripple from the Rectifier would probably be smooth enough for welding. Now you make me want to go take the cap out and try it. Once I get this all worked out, my father has the same welder that we will repeat the best practice on. Shure would be easier fitting just the rectifier in that tight space.
Adam Hill
Joined Jan 26, 2016
7
I thought the same thing about this welder until I took it apart. Granted this thing is anemic compared to Miller and only a fraction of the cost. What I found inside is the trigger switch seemed to operate a relay that energized the primary coil on the transformer. I also thought it odd that the primary coil is the tapped coil to select the "HI/LOW" voltage. I was expecting to see a tapped secondary. By the was this is the cheap flux core 125 welder sold by Northern tool. I got this for Christmas.
shortbus
Joined Sep 30, 2009
10,050
Never welded with one of the small ones like that, but have used many different brands of industrial ones, and they all did the after spark. And another difference is the industrial ones don't switch the primary to start and stop the weld. An inductor/choke is the usual form of output smoothing in a welder not a cap.
SLK001
Joined Nov 29, 2011
1,549
I don't see how. The 89,ooo uF cap doesn't hold enough energy to "smooth" things out. Especially when you are discharging a continuous 55 or so amps while you weld.
I converted my 180 amp Lincoln to DC for stick welding. It does quite nicely without any cap.
Adam Hill
Joined Jan 26, 2016
7
An update
I removed the cap and am now running just straight rectified DC. I really cannot tell any difference in the "smoothness" of the weld. What I do notice is much less splatter, more even steady arc, and better penetration. Since then I have converted my fathers welder in the same manner and got the same results. And of course without the cap there is no longer a zap if you touch the tip to the work after a pass.
Thank you all so much for the information!!
