What was the measurement relative to? --- FWIW it sounds as if you've a 'ground fault' somewhere -- Either in the cap itself or the assembly to which the case of the cap is mounted...While I was repairing a PC PSU(230V) I accidentally touched the metal top of mains smoothing capacitor.Well I received a small shock similar to placing a 9V battery on your tongue. I measured 130V at top of the cap, Is this normal?
Black probe was placed on neutral line off the 3pin plug and red probe was on top of the cap.What was the measurement relative to? --- FWIW it sounds as if you've a 'ground fault' somewhere -- Either in the cap itself or the assembly to which the case of the cap is mounted...
Best regards
HP
IMNSHO enough current to 'feel' represents excessive leakage! -- How is the Cap mounted? Is its metallic case electrically connected to the PSU assembly at any point? -- If not, the problem is isolated to the capacitor...Black probe was placed on neutral line off the 3pin plug and red probe was on top of the cap.
If it's a standard electrolytic it is polarized and, hence, not a 'mains filter' but, rather a post-rectifier filter, decoupling filter, etc...It's standard 200V aluminum electrolytic cap. It's not connected to anything but the PCB trace.Only low voltage side of PSU is grounded.
That is not a line-isolated node --- So... I feel the condition may appropriately be regarded as 'normal' --- Even so, I advise performance of the 'safety checks' outlined in post #6 -- To wit:Here:
http://320volt.com/wp-content/uploa...atx-circuit-sss2n60-tda865-pc817-mje13007.png
Top left corner C1,C2 are the caps.Only C2 reads 130V across it.
Best regardsplease verify that potentials on all output leads (including 'ground returns') are at negligible AC potentials with respect to chassis and mains ground!
I tested ground and its is working as intended.I guess that this fenomene is normal,now just to figure out whats wrong with the psu. It only shuts down when 12V line is under load.That is not a line-isolated node --- So... I feel the condition may appropriately be regarded as 'normal' --- Even so, I advise performance of the 'safety checks' outlined in post #6 -- To wit:
Best regards
HP
Many PSUs of that 'caste' 'stall' on overload -- Are you certain the difficulty is with the PSU (as opposed to the load)? -- If 'yes' -- At approximately what current level does the unit shut down?I tested ground and its is working as intended.I guess that this fenomene is normal,now just to figure out whats wrong with the psu. It only shuts down when 12V line is under load.
Yes the problem is in the PSU.I'm running a DC motor that draws around 5A max.Many PSUs of that 'caste' 'stall' on overload -- Are you certain the difficulty is with the PSU (as opposed to the load)? -- If 'yes' -- At approximately what current level does the unit shut down?
Best regards
HP
Inasmuch as electric motors exhibit significant starting currents I suggest a purely resistive test load...Yes the problem is in the PSU.I'm running a DC motor that draws around 5A max.
I can use the motor on 5V line without problems but as soon I plug it into the 12V line psu shuts down.Generally if I try to draw more than 10W from 12V it just shuts down. Sometimes I have to flick the PSU switch few time before PSU turns on and this only occurs if 12V is loaded or it was loaded.I guess the problem is in some bad cap but I just cant find any which look bad, already replaced cap on 12V line and it hasn't solved the issue.
Please be advised that, for a given load, the current drain will be 2.4X at 12V...as soon I plug it into the 12V line psu shuts down
Quite likely... --- For starters please check C20I guess the problem is in some bad cap
Replaced C20 and problem is still there.Please keep me posted! -- I've more ideas should difficulties persist!
Best regards
HP
Not in my dictionary. Please educate me.fenomene
Ok... Before getting any 'deeper' please check C18 and C19Repl
FWIW, IMO context suggests the intended word was "phenomenon"?Not in my dictionary. Please educate me.
