Capacitor polarity in gyrator
hrs
Joined Jun 13, 2014
538
I'm working on a modified BOSS HM-2 which uses gyrators for tone control. It has an odd capacitor value (C35) of 1.5uF. I happen to have some tantalum caps with this value. Then I noticed the C35 polarity on the BOSS schematic is opposite to some schematics you can find online.
I did an LTSpice simulation which shows the signal polarity reversing.
Assuming my simulation is correct, my question is: Will a tantalum cap stand up to this abuse? Otherwise I have a "normal" 1uF electrolytic that measures 1.2uF and I might use that.
38,856
Electrolytics (including tantalums) are normally polarized, have a wide tolerance, and are thus not well suited to use as frequency determining components in audio circuits (they are okay for power supply filtering).
Much better to use a film capacitor, even though they are physically large.
hrs
Joined Jun 13, 2014
538
My experience with tantalums is that they are not tolerant to polarity reversal. AVX has this study of the effect of 10% reversed polarity: https://www.avx.com/docs/techinfo/17_Reverse.pdf
I don't see any reversed polarity in your simulation. Could you consider a 2.2 uF and 4.7 uF non-polarized in series (about 1.498 uF)?
Thanks, I kind of expecting that. But I didn't think of the excellent suggestion to use series caps. I've read somewhere that if you put polarized caps back-to-back you get a NP cap. But there was a price to it which I forgot. Anyway, I think I'll be going this route, thanks again.
The biggest film capacitor I have is 1uF and it's indeed large. Since this is just a one-off I can hand pick one that is good. I went through my bag of 1uF elco caps to find the 1.2uF I mentioned earlier and most are actually quite close, within a few %.
