Capacitor life
sgr
Joined Jun 27, 2017
34
How to calculate the capacitor Life. For example I have to design a Product having life 10 Years. How to insure that used capacitor in the product is also having life 10 years.
sgr
Joined Jun 27, 2017
34
I have 2 capacitor and details are as below....
Capacitor 1: 10uF, 50V and size 0402
Capacitor 2: 10uF, 50V and size 0603
Since both the capacitor are having same value and voltage ratings only the size is different. So what are the Parameters (Geometry, Construction or Technology) are involved to reduce the size ?
SamR
Joined Mar 19, 2019
5,494
Have you looked at their datasheet? Not being electrolytic, they should last "forever" unless under heavy duty and not protected from overvoltage.
Alec_t
Joined Sep 17, 2013
15,119
If two caps differing only in physical size are used under identical electrical and mounting conditions, the larger one is likely to be less thermally stressed, so should have a longer life.
DickCappels
Joined Aug 21, 2008
10,659
The life of a capacitor can be estimated from its rated life and temperature rating at a specific set of conditions.
Try this:
You will probably also find this one helpful:
