Capacitor in parallel with a Resistor circuit analysis
ghulen
Joined Jan 4, 2018
14
If a capacitor is in parallel with a resistor, is the voltage across the resistor = to the voltage across the capacitor? For example, in this picture Vc = i1(2ohm)
Tonyr1084
Joined Sep 24, 2015
9,744
To answer your question regardless of the picture, yes, the voltage across the resistor parallel to the cap is equal.
In your picture I don't see any capacitors.
As for what is different in the same parallel circuit - the current is different. The voltage remains equal.
38,927
By definition, all parallel elements in a circuit must have the same voltage across them.
If not, then they are not in parallel.
WBahn
Joined Mar 31, 2012
33,324
In the picture he is doing a steady-state analysis and so replacing the capacitor with an open circuit.
