Thank you all for viewing my posting here in the forum,
I have included a circuit diagram here to show what my present thoughts are on this topic. I am looking to capacitive couple the signal from a spark plug wire from a motor car and use this to monitor only. I know there are other ways to do this but I want to use this method to prove my thoughts on building the circuit.
I am winding a solid core wire(.5mm thick) 'x' times( I have varied from 1 to 7 times) around the plug wire. This then goes into my circuit as shown.
I am using a led as the load to show that the circuit is functioning properly. I am wanting to have .01A current thru the led.
I do not know what the resistor R1 should be here. Do I calculate this value based on the voltage from the coil? I thought this would be the correct way to design this but my end result at test (distributor spin fixture) did not work as I used 3MEG for R1 assuming 30kv from coil. I should see the led on for approx. 470mS when using the values for R2 and the cap. R3 is calculated with a 3.1 drop and a Vf to the led of 2v.
I welcome your guidance in helping me discover how I can make this circuit work.
Thank you,
Peaches
Thank you,
Peaches
