After I resetted my router yesterday I cant connect to dsl . It worked fine before I did the reset which I regret really bad . The LED should always be on to show that theres dsl but its just keeps blinking since yesterday morning .I called my Internet provider and they can fix it with in two days . But the problem I guess is coming from my router which a modem at the same time since I am sure that I am using fritz box 7412 I entered the username ad password provided by my isp correctly but the main problem is the dsl led that keeps on blinking I tried power cycling the router dozens of times with no sucess also resetting the fritz box to factory settings . I am pretty sure that the cabling is correct Maybe these pictures can help apologies that it is in german but maybe you can use google translate
I am very confused because it should work
