Can you use one base resistor for multiple transistors?
christogeorge
Joined Dec 9, 2017
In the circuit attached has a transistor connected in parallel configuration.
can I use single base resistor for the 2 transistors(2N2222A)
DickCappels
Joined Aug 21, 2008
10,660
Yes you can, but think about it for a minute: Why don't we see people doing that all the time?
Transistors will share base current, but without the base resistors to swamp out voltage differences between the transistors the degree of sharing is uncertain.
dl324
Joined Mar 30, 2015
18,376
Welcome to AAC!
That technique is best used with matched transistors. If you use dual transistors (in the same package) they'll be more likely to be matched and will track better over temperature.
