Can you transmit video at 30 mhz?
Man10
Joined Jul 31, 2018
207
Can a 28 mhz radio signal transmit live video? it is a black and white signal. No color. Resolution is 480 lines. Each line consist of 640 pixels. A video compression method is used that only transmits the differences between frames. Greyscale is 8 bit.
ronsimpson
Joined Oct 7, 2019
4,906
28.000–29.700 MHz — is the internationally allocated 10‑meter amateur radio band, used worldwide for licensed amateur (ham) radio operations. We have been sending video for decades, without compression.
You might be interested in this. HAM TV
ci139
Joined Jul 11, 2016
2,043
can you transmit live video at 30 mhz? The resolution is 100 lines. Each line consist of 100 pixels. No color, instead a black and white image. A video compression method that only transmit differences in frames is used.
the option to consider is latency . . .
100 by 100 px ~ VBR ~ B&W ~versus~ different monochrome ~ digital format
frame 25 nibbles or 13 bytes !from the least! the entire frame 10k/8 1250 bytes (if no blanks are sent)
otherwise
you can put 2 flag bits for each line SR
S -- skip = no change
R -- reverse start from line end
which enables you to skip "no change" at the edge there is more static pixels
anyway the worst case 1250 bytes per frame B&W (bitmap)
the decent frame rate is above 18 to 22 fps ~~ say a PAL 25fps
1.25 · 8 · 25 kbps = 250 kbps - would be a headache for most commercial/std. codecs for high contrast B&W bitmap
the rate itself is not that high though ... if you manage to achieve different polarity modulation for each half cycle it'd require (250k / 2) = 125 kHz to transfer raw bit stream with no frame start/end markers
at 30 MHz such would leave (30/0.125 = ) 240 // – 1 = 239 free clusters at reserve
which hints the Grayscale resolution limit = 2²⁴⁰ levels from B(0%) to W(100%) --e.g.-- 240 bit colour(/gray)
PS! -- the problem with Grayscale differential pixels is that they tend to have double range of the palette
e.g. :: W – B = +(2²⁴⁰ – 1) vs B – W = –(2²⁴⁰ – 1) - - - however you can use a <positive offset> MOD 2²⁴⁰
??? . . . what is your question again
28,639
Can a monochrome composite video signal be transmitted using a 28 Mhz carrier? Using Amplitube Modulation?
Short answer: YES. Full Answer: YES, BUT probably not legally in many areas.
Consider that full color NTSC video is transmitted over US TV Channel 2, it can be done. So the answer is "Yes, BUT."........... (The technical details are rather complicated)
BUT consider that a broadcast TV channel is SIX MEGAHERTZ wide, which does also include the stereo sound channels.
So the bandwidth is not small, and there are a whole lot of legal considerations involved, because of there being license requirements to transmit anything at all.
