Can You Calculate The Input Impedance?
MrAl
Joined Jun 17, 2014
13,776
It seems to me that the circuit is only symmetric in a limited sense, namely that if Z5 is removed, the impedance at node 5 is infinite with no load at node 1, and the impedance at node 1 is infinite with no load at node 5, and if the opamp gains are infinite. Otherwise, it would only be symmetric if Z2 = Z3 and Z1 = Z4, which is not the case.
Hello again,
Yes i was assuming you were using a voltage source as drive for the circuit. With a voltage source in the input the impedances appear to be zero.
With nothing connected to the input, then the impedances i get are:
node 5: Z5 (or simply R5)
node 3: -R3*R5/R4
node 3 to node 5: zero
Note yes, one of them is negative.
LvW
Joined Jun 13, 2013
2,035
In post#9 the input impedances at the nodes 3 and 5 are wanted.
My answer - as far as node 5 is concerned - was given in my post #14.
Now - here is my answer regarding node 3:
When we remember how Antonious GIC was developed from the basic GIC circuit (see my post #7), it is best to go back to the series connection of the two NIC blocks (jpg file GIC-origin my post #7). Here, both inverting inputs still share a common node which is identical to the node 3 under discussion.
Without any new calculation, again it is possible to give immediately the input impedance:
* It is known that the most right classic NIC block (elements 3,4 and 5) has the negative input impedance Z3,1=-Z3*Z5/Z4.
Realizing that the grounded element Z5 appears in the numerator, we can say that the input impedance Z3,2 for the most left NIC block (elements 1,2 and "infinite" - no grounded part at the "+"node) will be infinite.
*Hence Zin3=Z3,1||Z3,2 with Z3,2=infinite and Zin3=Z3,1=- Z3*Z5/Z4.
Hello again,
node 3: -R3*R5/R4
Why would there be any voltage sources other than the one used to determine the impedance (resistance in this case) at a node--the source in the "ohmmeter" so to speak?
OK everybody. Next determine the resistances seen at the five nodes with the opamps remaining ideal
except the internal gain assumes 3 different values, namely 1 , 3/sqrt(5), and 2.
Give the results as 5 element lists; e.g., the result for the question posed in post #9 would be: {15/8 , 0 , -15/4 , 0 , 5}
MrAl
Joined Jun 17, 2014
13,776
And did you calculate the impedance across the two named nodes yet?
MrAl
Joined Jun 17, 2014
13,776
Not sure why i did that to start with, but it did turn out a little interesting just the same in that apparently when there is a voltage source at the input all the nodes show zero impedance to ground. You could try to duplicate that if you like.
Ok i'll give it a shot a bit later today i hope.
Did you yourself calculate the other impedances too or no? And if so, did you get similar results?
Here's what i get for the node 5:
Z=((Ap*R3+Ap*R2+Am^2*R2)*R4*R5)/(Ap*R3*R5+Ap*R2*R5+Ap*R3*R4+Ap*R2*R4+Am^2*R2*R4)
where Ap=A+1, and Am=A-1, and A is the internal gain.
So with A=1 for example i get:
Z=R4*R5/(R4+R5)
The values you and LvW got are correct. Don't you find it interesting that nodes 3 and 5 show finite resistance to ground, yet the resistance between the two is zero?
MrAl
Joined Jun 17, 2014
13,776
Yes, in fact, i know there were several times when i had to use feedback to INCREASE the input impedance of an amplifier type circuit, but i cant think of a single time when i had to use feedback to DECREASE any impedance anywhere (assuming an op amp output is low enough of course or else we use a driver, but that's different). In this circuit, we see the circuit react to an excitation in such a way that it keeps the two differential voltage equal across those two nodes, and so we dont get a differential voltage change with any kind of current injection.
That's quite interesting to me and i was thinking of maybe trying to create a new circuit with just one op amp that reduces some impedance to zero like that, maybe the input impedance. That would create a sort of 'ideal' current shunt maybe. Something to think about anyway.
Normally we try to increase the input impedance but that would be for a voltage input not current.
Maybe another challenge :)
[LATER]
Turns out it is much easier than constructing a temperature compensated shunt circuit. I'll save this for later.
LvW
Joined Jun 13, 2013
2,035
General feedback considerations:
* If the feedback signal is a current (inverting opamp amplifier, BJT stage with RB between C and B) the input impedance is always DECREASED.
* If the feedback signal is driven by (sampled) an ouput voltage (rather than current), the output impedance is always DECREASED.
(in all opposite cases the impedances are INCREASED).
And - yes, I agree that the impedance between nodes 3 and 5 is zero (for ideal opamps) because the voltage difference between both nodes disappears.
