For my TB6600 motor design I had 5 x 1R, 1W, +/-5% resistors in parallel (making the effective resistance 0.2mR 0.2R) for current sensing. However, is it ok to use something like this for current sensing?
Your calculation is off (or the communication of your result is in error).For my TB6600 motor design I had 5 x 1R, 1W, +/-5% resistors in parallel (making the effective resistance 0.2mR) for current sensing. However, is it ok to use something like this for current sensing?
Ah I see. So you are suggesting the use of Rds as a current sensing resistor?There is also power Mosfets with extra pins that indicate the current through the device.
Max.
No because Rds depends on gate voltage (and charge state of the gate since a MOSFET gate is a natural capacitor). Those MOSFETS have an onboard precision trimmed low ohm resistor. Some actually have an amplified output (if it is still in production) but I haven't looked at them in a long time.Ah I see. So you are suggesting the use of Rds as a current sensing resistor?
This sounds very interesting. Can you suggest a few part numbers?No because Rds depends on gate voltage (and charge state of the gate since a MOSFET gate is a natural capacitor). Those MOSFETS have an onboard precision trimmed low ohm resistor. Some actually have an amplified output (if it is still in production) but I haven't looked at them in a long time.
