Hello
I have a pressure sensor board, supposed to be 0 to 40kpa. (It is not) Common cheap board using a fixed gain (128*) HX710B serial 24 bit AD. The board works with but has range problems. The Sensor has a 25mv or so offset, 50mv range, and allegedly outputs -20kpa to +20kpa. This would be cool but the range is clipped in the HX710. +/- 3.9*Vref, +/-19.5mv @5V In fact I measured a wall to wall range of -15.2 kPa to +5.3 kPa. So there was clipping on the low end also. Here is the schematic of the board. Where, how, what, can I do to shift the 25mv offset down so I can use the upper end that is getting clipped, or what can I do to fit the entire range into the AD limits? Bridge resistance is reported at 4k to 6k Ohms.
Thanks for the thoughts and help..
