Im kind of a newbie in the electronic world and need help with my battery box project.
What I'm doing is housing a box with two 12vdc lead sealed 8,5ah batteries.
The switch selects between 12vdc and 24vdc and leds indicate which is on.
I want the Output terminals to be hot until i plug in a cord that acts as a momentary trigger which will
only be hot when the button is pressed.
There is a shunt on the cord end that bridges the 12v/24v positive side that actuates a 12v relay.
the LED's i was thinking of using were red 12v ones with a resistor to protect it when it flips to 24vdc.
Does any of that make sense? Please let me know how i can improve upon this.
Also the charger just plugs into the wall and wont be used while using the battery power at the same time.
Thank you so much in advance for your time.
