Why would you think it was not correct?Its data sheet shows internal circuit explanation for pin 1. Is that correct ?
The input signal varies the voltage between the base and emitter. That will make the collector current change.Thanks. Antenna signal entering across 1K to emitter node and gnd. ¿?
