Can I use an HDMI cable for a control pendant?
tombj
Joined Jul 29, 2020
I'm putting together a pendant control for a CNC machine, and need about 14 conductors. I can get inexpensive HDMI female screw terminal breakout boards and a 6' HDMI cable would be perfect form for this application. The wires are for x/y/z axis selection, movement resolution (x1, x10, x100) and a manual pulse generator encoder with +5v,0v A and B. I'd use 24ga wires from the breakout board to the controller connector. Any reason this will not work?
sghioto
Joined Dec 31, 2017
8,750
Google says cheap cables use 30 or 32. A good cable should be 26 or 28 if only a short length.
I certainly would not use a cheap cable.
Steve G
