Can i use 27mhz rf power bjt in a vhf power amplifier ?
Maz2858
Joined Jan 27, 2021
27
Hi, i have 2 27mhz rf power transistors and i want to know if i can use them in a vhf amplfifier
The transistors are c2314 + c2078
The maximum frequency in the datasheets are ~150mhz so can i use them at ~90mhz for power amplification
Thx
Papabravo
Joined Feb 24, 2006
22,115
Thx
Sure - knock yourself out. BTW the small m in "mhz" actually means millihertz, but we knew what you meant. The correct usage is the capital "M" for MegaHertz.
I know - picky point, but there it is.
sparky 1
Joined Nov 3, 2018
1,218
2SC2314 is technically a VHF transistor. Ft vs Ic curve might peak at 25 to 45 Mhz. I am not sure, just as an example.
The frequency transition might be 5 times like ft 300 MHz the signal to noise however might be unusable. I have a few circuits
made years ago ( turned out not so good) did'nt have complete RF datasheet and VNA were expensive, today hams have mini vna they might
have tested a cb transistor on 10M 6M 2M. Possibly you may want an MRF transistor for your vhf project.
Maz2858
Joined Jan 27, 2021
27
That is my point. Transistors are not made for a specific frequency, as far as I know. Can you link to the datasheet?
Bob
Just look on internet for the datasheet, theres written something like "application : 27mhz amplifier" or something like that
sparky 1
Joined Nov 3, 2018
1,218
The Sanyo datasheet above p.3 Collector efficiency test , adjusting the 100pF you would expect typical output 1.8W with power input of 35mW at 27 MHz this holds true for higher frequencies interpreting graphs on p.3 the fT - Ic 180mA 10V 290 MHz
One example of a second stage might use RD12MVS1 so you can see full datasheet PA level
https://pdf1.alldatasheet.com/datasheet-pdf/view/426417/MITSUBISHI/RD12MVS1.html
