Can I substitute a different mosfet instead of irlz44n?
bigjoncoop
Joined Feb 1, 2019
204
jpanhalt
Joined Jan 18, 2008
11,087
Of the two choices you offer, the AOD4144 is probably the better choice as it is turned on at 4.5V; the SW630 is not. Only problem with the former is its Vds is limited to 30 V rather than the 60 V of the IRLZ44.
What is the maximum voltage it will be switching?
bigjoncoop
Joined Feb 1, 2019
204
4.2v.. Only one 18650 cell
bigjoncoop
Joined Feb 1, 2019
204
No problem then.
Okay. Thank you so much for your quick response. I really appreciate it.
What are the most critical characteristics / values of a mosfet when trying to find a equivalent mosfet to substitute another?.
I'm assuming first of all is, N-Channel, P-channel, NPN etc...
bassbindevil
Joined Jan 23, 2014
924
Not an expert, but...
N or P channel
whether it will turn on full with a logic-level gate voltage.
max current
max voltage
Rdson: how low the resistance is when turned on
The first two can potentially be worked around by changing between high and low-side switching, and finding a way to drive the gate with something like 10 volts. Increasing current and reducing Rdson can be achieved by paralleling more devices, but that will also increase gate capacitance, which can affect switching time.
ci139
Joined Jul 11, 2016
2,039
i had made a comparison chart for basic-simple characteristics previously , including ...
  • Channel type / P , N
  • Technology / a physical construction/principle
  • U.DS (V)
  • I.D (A)
  • P (W)
  • R.(DS)ON (mΩ)
  • T.j.Max (°C)
  • I.D(estimated!) 100°C (A)
  • I.D(while specified) 100°C (A)
  • I.D 25°C (A)
  • I.DM Pulsed (A)
  • Q.g (nC) -- total gate charge
  • dt ON (ns) -- ON delay
  • t Rise (ns) -- rise time
  • dt OFF (ns) -- OFF delay
  • t Fall (ns) -- fall time
  • dt Up (ns) -- dt ON + t Rise
  • dt Dn (ns) -- dt OFF + t Fall
  • f.pk 1:1 (?50%) (MHz)
  • f.duty 1.5% (kHz)
  • Vth (V) -- threshold voltage
  • SOA diagrams -- safe operating area/conditions
about : AN11158.pdf - Understanding power MOSFET data sheet parameters
better : Infineon-MOSFET_OptiMOS_datasheet_explanation-AN-v01_00-EN
ci139
Joined Jul 11, 2016
2,039
AOD4144 n channel
SW630 N channel
AOD4144 SDMOSTM trench technology -- low voltage (30V) have a lower R(DS)ON 14mΩ - thus - a higher possible drain current 43A @ 100°C
SW630 advanced VDMOS technology -- high voltge (200V) devices have usually and a higher channel ON resistance 400mΩ - thus - a lower allowed draincurrent 6.8A @ 100°C
AOD4144 -- gate charge 28nC , power limit 2.3W , peak current 110A , td.on+t.rise : (7+10 ns) , dt.off+t.fall : (22+5 ns) , Vth 1.2 ... 2.4 V
SW630 -- gate charge 27nC , power limit 72W , peak current 36A , td.on+t.rise : (40+140 ns) , dt.off+t.fall : (150+140 ns) , Vth 2 ... 4 V
* below Vth the mosfet practically does not conduct thus -- won't dissipate any power as \( P=U·I\ ,\ P=Lim_{I→0}\ U·I=0 \) ← also important to know is → \( I_{D} \) versus \( V_{GS} \) / versus \( V_{DS} \) -- e.g. -- how much gate voltage to apply and what should be your power supply voltage to reach up your desired drain current
** the rise and fall times are not so essential if you don't go high speed × high efficiency switching
*** the channel on resistances are not so critical if you won't pass high currents through your device -- e.g. -- currents that would cause a considerable power loss on your mosfet . . . ← if such has significance in a context of the rest of the circuit . . .
