Can I make a sine wave inverter this way??
rockgro
Joined Sep 7, 2021
19
I recently saw this video where he uses SPWM to create a sine wave inverter.
link-
But I have a different approach to this.
Can we create sine wave signals using a Wien-bridge oscillator circuit and then an Emitter follower circuit using a power transistor to deliver high current? Is that not correct??
tepalia02
Joined May 13, 2022
37
If you see the comment section, you'll see some criticism on the design and parts list. I think you'd better take those into consideration.
rockgro
Joined Sep 7, 2021
19
But I am asking about my idea! not what he did in this video!
My Idea:
38,948
In concept, yes, but not good way in practice.
Depending upon how much AC power you want, it has very low efficiency, and will waste a lot of power as heat.
That's why SPWM is used, as it has much higher efficiency.
Papabravo
Joined Feb 24, 2006
22,116
My Idea:
It will be much easier to do this investigation with a simulator. It is easy to do efficiency calculations and you can change your assumptions and compare the efficacy of various strategies.
rockgro
Joined Sep 7, 2021
19
Ohh ok! Ig I need to try out and figure out the efficiency of this system!
But can u tell an estimated efficiency of this type of system?
Papabravo
Joined Feb 24, 2006
22,116
Less than 50% for a conventional emitter follower with a BJT power transistor. You might see some improvement with a low Rds(on) MOSFET in a source follower configuration, but it will pale in comparison to an SPWM system. Hitting 90% is fairly typical. Getting to 95% takes some careful analysis, understanding and component selection. The next few %-age points will not come without considerable effort and skill.
rockgro
Joined Sep 7, 2021
19
Ok Thanks!!
My Idea:
That's just not a practical way to convert power today. We once actually used large DC power bank supplied audio amplifiers as inverters for sensitive circuits before modern digital methods were practical.
With modern digital signal generation it's easily possible to have a few hundred watts of polyphase output power in a small package.
https://forum.allaboutcircuits.com/...r-for-3-phase-115v-supply.181424/post-1665711
rockgro
Joined Sep 7, 2021
19
