Can I connect reed switch with microcontroller using 15 meter cable ?
Layan_AK
Joined Mar 28, 2017
79
Hi all,
I want to connect reed switch with Microcontroller .
The distance between the switch and Mcu about 15 m .
Can I connect the switch with only pullup resistor to Mcu ?
Regards :)
ericgibbs
Joined Jan 29, 2010
21,569
hi AK,
Will the 15 mtr cables path be exposed to high external electrical noise/fields.?
ie: laid alongside other existing wiring .?
Will it be a twisted pair or screened cable.?
Indoors or Outdoors.
E
Layan_AK
Joined Mar 28, 2017
79
hi AK,
E
no other wiring close to cable ..
it will be outdoor.
what is the difference between twisted and screened ?
regards :)
ericgibbs
Joined Jan 29, 2010
21,569
hi,
A twisted cable is two conductors which are twisted at approx 5 turns per inch, along their full length.
This helps to reduce the electrical noise picked up by the cable from external electrical sources.
Screened cable can be a single conductor with an overall braided copper screen along it full length.
or twin conductors with braided screening.
You should consider if the wiring is out doors, the possibility of a lightning strike close by.
E
Layan_AK
Joined Mar 28, 2017
79
hi,
E
what is the best twisted or screened ?
how can prevent any noise or lighting strike to affect the mcu system ?
using twisted or screened enough ? Or there is a specific connection to do that ?
^_^
ericgibbs
Joined Jan 29, 2010
21,569
hi,
I would use twisted pairs, look at this diagram.
It will give some protection against over voltages and electrical noise.
It is almost impossible to protect against a direct strike, the keep the wiring out of trees etc.
E
Layan_AK
Joined Mar 28, 2017
79
hi,
E
thanks alot eric :)
could you explain the purpose of this part of the circuit ?
also i need to read the switch as an interrupt ,should i use hardware debounce ?
regards :)
Dodgydave
Joined Jun 22, 2012
11,395
If you're worried about spikes and electrical interference, i would use an opto-couper to switch the pic pin, and let the reed switch feed the opto-couper using a two core screened cable.
ericgibbs
Joined Jan 29, 2010
21,569
hi AK,
This LTSpice simulation of the circuit I posted will help you visualise what those components are doing, ref image
The circuit will also de-bounce the uSw contact signal, to increase the de-bounce period increase C1 value, say to 47n
The sim shows 2 idealised interference pulses 0f +/-10v amplitude.
E
ericgibbs
Joined Jan 29, 2010
21,569
hi AK,
The datasheet shows it as an open collector output, capable of operating from a 5V supply., switching close to 0V
I should try it.
E
EDIT:
I guess you know that the connecting cable will require 3 conductors?
Twin screened, one wire for +5V and another wire for the Output.
Screened overall as 0V Ground return.
Also add 1uF cap across the Hall device power rails at the remote Hall end of the cable.
GopherT
Joined Nov 23, 2012
8,009
If your biggest concern is lightning, simply use a
- 5.6V zener to prevent over voltage from electrical interference,
- a "poly fuse" for over current (lightning)
- 22 gauge or smaller wire for connection to the sensor
22 gauge wire will fuse (melt) at less than 50 Amps which is well below the maximum current handing (100A) of the polyfuse.
philba
Joined Aug 17, 2017
959
Screened = shielded?
Frankly, lightning is going to take more protection than diodes, fuses or optos. Best bet for lightning is to provide a super low impedance path to earth (aka, lightning rod). Using the thin wires for the sensor is a good idea because, as pointed out above, they will fuse. But before they do, there's a good chance of damage from secondary effects so use some of the other things mentioned.
Here's Mouser's write up on the lightning topic. For the tl:dr folks, it says have a single, central, big fat direct connection to earth as a path for the lightening. Do not have multiple connections to earth.
38,806
A standard opto isolator by itself will likely not provide much protection against a direct lightning strike whose voltage could easily bridge the gap between the input and output pins.
You might add a lightning arrester circuit, such as used for TV or Ham coax cable, which use a gas tube spark gap to shunt away the high voltage pulse to ground.
The arrestor needs to be connected to a low impedance path to a ground rod, of course.
