Can I connect 2 TPA3118 60w Mono Module to create a Stereo Amplifier?
BLiND18514
Joined Apr 2, 2018
13
This is the only amplifier I had lying around and since it was a mono amplifier, it only accepts 2 inputs. By using two boards at the same time feeding the same signal wherein the LEFT channel and GND goes to the 1st board and the RIGHT channel and same GND to the second board will it work smoothly as a stereo amplifier creating a 120w Amplifier? ~(Also, I'm using only 1 power supply to power the two boards.)
38,909
No.
According to the data sheet, the TPA3116 (which is on the board you posted) is a stereo amplifier, not mono.
But the two stereo amps can be connected in bridge fashion to give 60W into a 8Ω load.
Is that how yours is connected?
If so, it can't be further bridged by using two amps.
BLiND18514
Joined Apr 2, 2018
13
No.
~Well technically I don't really understand how the IC was connected in the board but either way it says "60w Mono Amplifier" and thus, can there be any ways to make it a stereo amplifier out of this 2 boards?
Ylli
Joined Nov 13, 2015
1,092
As long as you keep the outputs separated, one board to one speaker, the other board to the other speaker, then yes you can use two boards to form a stereo amplifier. I think crutschow believes you want to cross connect the two boards.
38,909
Well in his first post he said he want to create a 120W stereo amp but I guess he meant 60W per channel.
In that case yes that will work because they are working as two completely separate amplifiers.
BLiND18514
Joined Apr 2, 2018
13
So basically I'll only feed LEFT CHANNEL to the first board and RIGHT channel to the second board in the input. Will it be okay if they have the same ground in the input?
BLiND18514
Joined Apr 2, 2018
13
~So basically this connection will be okay and there'll be no magic smoke or something right? OR should I isolate the powersupply of the two?
