I could not find ref. to OC V of 13.5; from cell count V = about 16 V, Nothing beats real measurements.
If you go on Aliexpress or Alibaba and search you will find both products and if you look at enough of them you will find the detail...The link to the battery in the 1st post shows only 12V, 3000Ah and nothing else. It looks like a Li-PO.
It says it is 100% safe then it might have a protection circuit in it.
It has only 2 wires then it might have a balancing circuit in it.
Link to solar panel https://www.aliexpress.com/item/32970372014.html (One of many)
Annoyingly I can't find link to battery I had earlier, but I seriously doubt its 3000mAh, its too light at 156g and 14mm thick rules out most cylindrical cells (14650 wont give 3000mah and anyway won't fit) so must be <4mm pouch but even that would struggle to fit those dimensions,,,
