I bought this solar charge controller (CMP12 Solar Charge Controller 10 AMP 12V/24V auto switch), which I was going to use to charge (lithium-ion super rechargeable battery pack (12V, 3A). I know this will harm the battery, my question here is how much damage will the solar charger will cause to the battery over time, is it a long duration damage process or a short one (instantly damaged)? I will be using this for a small project which I will be using for a few times for only demonstration purposes. I would like to know if there is any way to slow down the damaging process of the battery.
More Detailed information about the mentioned components:
Battery: https://ram-e-shop.com/product/battery-li-12v-3000mah/
Solar charge controller: http://www.gadgetpower.co.uk/12V_24V_10A_charge_controller_CMP12.pdf
Thanks in advance!
Thanks in advance!
