Can i ask for noload current of a transformer
ireallyneedhelp123
Joined Jan 5, 2017
0
for a noload current of a transformer i can say that , is zero if there is no load being connected ? or isit about 5% of the input current ?
and for non ideal transformer the current from the source depends on the noload current and the amount of current drawn by the load ?
38,855
The magnetizing current typically is about 5% of the full-load current, but it is mostly inductive reactive current so the power loss from that is less than for a resistive load of that current.
The total primary load current would be the phasor combination of the load current and the magnetizing current.
ireallyneedhelp123
Joined Jan 5, 2017
0
1)So given the option to just choose either zero if there is no load being connected or is about 5% of the input current? which will you choose ?
2) And for non ideal transformer the current from the source depends on the noload current and the amount of current drawn by the load ? will this statement be true or most likely false ?
ireallyneedhelp123
Joined Jan 5, 2017
0
nono i just want to know whether my answer is correct or not so just checking only haha but to me under noload condition i can simply treat it as zero since the 5% can be neligible ? while for my second question i think the source do depend on no load current and also the load current
