Can common house dust cause short circuiting on a PC motherboard?
tindel
Joined Sep 16, 2012
939
Pb-free is one of the most expensive and useless initiatives on the planet. Nothing green about it and solder doesn't magically jump off a pcb board in a device and put itself in your food where it can cause harm.
Even working in environments with lead-based solder, I don't worry about it, but do try to remember to wash/rinse my hands before I eat.
tindel
Joined Sep 16, 2012
939
I suspect either the fan or cap... look for bulging caps on the boards. If it's got that much dust, it's probably time to replace the computer anyway.
It's not the lead that causes tin whiskers.
Looking up what's in silver solder I found this. It surprised me to see there's still some lead in silver solder.
We all agree on that point.
Lead is a countermeasure for tin whiskers.
https://www.semipack.com/blog/4-tips-for-preventing-tin-whiskers
Most material experts agree that stress is a catalyst for tin whisker formation. The material deposition process creates the initial stress, while interactions between the plated layer and the underlying substrate further exacerbate it. Eventually, the stress reaches a point where it forces some of the tin atoms outward. By subjecting the plated surface to stress-relieving treatments, industry professionals can release any stress in the layer and, consequently, reduce the risk of tin whiskers forming.
One of the most common methods of stress relieving tinned surfaces is solder dipping them in tin-lead solder. This process heats the material to above its melting point, allowing it to reflow and release stress.
https://www.electronicdesign.com/te...n-knowledge-mitigates-effects-of-tin-whiskers
Food is not the issue with tin/lead. People throw unwanted electronics in the landfill. The lead can leach out and make its way into our water. At least that's my understanding of it.
From my link above:
Recall that the expected environmental harm from lead in electronics was the impetus behind the RoHS legislative action. Lead was feared as a contaminant to groundwater. But many well-intentioned people overlook one important fact: elemental lead is not water soluble. Other sources concur: "Lead does not break down in the environment. Once lead falls onto soil, it usually sticks to the soil particles."5 When burned in an open-fire recycling operation, lead was feared to cause a poisonous vapor if inhaled. From NASA,6 the facts are:
  1. An open-fire temperature is approximately 1000°C, but Pb boils at 1740°C.
  2. Thus, the vapor pressure of Pb would be negligible, presenting little possibility of Pb vapor poisoning.
  3. Workers who solder with SnPb do not have high Pb levels in their blood.
In the end, there is no evidence that lead in electronics presents a health risk or causes environmental harm. However, many of the proposed lead-free solutions do pose environment problems and many are much worse for the environment.
ThePanMan
Joined Mar 13, 2020
954
I suppose well meaning uneducated people are making rules and laws. Not always do they represent the greatest level of knowledge.
ThePanMan
Joined Mar 13, 2020
954
As I believe I understand it - the Roman Empire fell (in part due to the breakdown of the family but also) due to the aristocracy consuming wine from leaded chalices. The wine leached out the lead which made the Roman leadership go crazy.
In Flint Michigan there's a whole ruckus over lead pipes and the high content of lead in the drinking water. So on the point of lead not leaching into the drinking water - I think I'm on the other side of that fence. I believe lead can leach into our water system. Along with Prozac, Xanax, Lithium and all kinds of other bad stuff. At least our fish are not depressed.
ThePanMan
Joined Mar 13, 2020
954
OK, Y'all - back on topic. Can common house dust cause short circuiting on a PC motherboard? In some circumstances yes. But for dust to carry low voltages it needs to be wet. Dry dust isn't likely going to be the cause of a failure due to short circuiting. Heat on the other hand, absolutely.
t_glover
Joined Mar 16, 2021
60
My employer had a fleet of vehicles that I looked after. One of them was
Dodge mini van. It was off warranty and it started having electrical issues.
The check engine light would come on as if there was a problem when I
plugged the scanner into it the scanner would not connect. The dealer
scanner would not connect either. If I disconnected the battery for a few
seconds the codes would clear and the scanner would connect.
One day the driver brought it me the speedometer needle had gone
all the way around and was stuck behind the pin the needle rests on
at zero. I took the instrument cluster out to see if I could just manually
move the needle back which I did. When it was out I noticed it had a lot
of dust on the printed circuit. I carefully cleaned the dust off and put it
back together and it never acted up again. All the harness connections
to the printed circuit were clean and tight so I don't think that was a
problem.
ThePanMan
Joined Mar 13, 2020
954
Automotive dust? Steam? Oil?
I believe you. There's nothing like eye witness proof. I still think there has to be something to carry the current. I don't see regular dust doing that.
28,651
Lead in solder as a hazard??? The whole push for ROHS was based on the presumption that lots of solder was present in electronic waste, which was, and still is, a LIE!! and how can that solder, quite well encased, be a hazard to people unless the waste is burned?? Leaching out into ground water in landfills?? Read the landfill rules and it is clearly not the case. There should be a caution not against eating circuit boards, though. Ingesting PCB materials is definitely unhealthy.
28,651
problem.
Consider road salt mist!! Consider that still, in many areas salt is dumped on the roadways in TONS PER MILE! And as it is mixed with water and turned into spray by tires rolling through the saturated salt brine, some of that mist is picked up by the heater system outside air inlets. And that warmed air circulates in the passenger compartment, and into every space eventually. For those who deny the damage and intensity of salt spray from road salt, just look at older cars in the salt using states!!
Teljkon
Joined Jan 24, 2019
267
To answer the OP I think the answer is a big fat Maybe. Its Fairly rare usually it is a heat issue but some dust could be a problem. Braap sound you heard could be many things. I, and I think it is fair to say most other people here, wouldn't start with a short caused by dust. You mentioned it serviced you for years. If its not a cap on the board it may just be age, and its time to GASP!!! Buy a new one. Or new to you any way.
I would grab my data off it by either transferring my hard drive to a new box or by pulling it off in small chunks when you can get it working. Then your free to fool with it and see if you can renew it, just worry about your data first.
28,651
The very few times that I have had computers make any sound like " Braap", it was from the hard drive looking for something and getting confused. Hard drives do wear and eventually fail, and sometimes they do it with being noisy.
Lo_volt
Joined Apr 3, 2014
377
Moisture is a definite issue when it comes to automotive electronics. That's why a lot of automotive electronic modules are potted or conformally coated with a moisture protective coating. The dust on the PC board on t_glover's instrument cluster PC board probably absorbed enough moisture to cause problems.
Indoors, this isn't usually a problem. Is it possible that the humidity level changed near your PC?
k1ng 1337
Joined Sep 11, 2020
1,038
I had an old HDD that would crash upon reading a bad sector. It was a small drive so I rewrote data often. Sometimes it would show a crash dump before going black, other times it would freeze and other times it would just restart and I could hear the disks spinning. A tool I was using detected a bad sector and I concluded bios/startup data was at that location and failure was only a matter of time.
I've wondered for a while at the true cause because I could never figure it out at the software level.
BobaMosfet
Joined Jul 1, 2009
2,211
I'll second dl324's comment. Tin whiskers are an issue with lead free solder. Solder that contains lead will not grow tin whiskers.
correct. Silver-solder has a whisker problem. I had to have an instrument cluster in my SUV replaced because whiskers finally caused it to fail.
Tonyr1084
Joined Sep 24, 2015
9,744
It should last for a very long time.
Thought I heard they have a limited number of times they can rewrite. Don't recall the number but I'm thinking 10K rewrites. But I don't know that for sure. But at the very least, dust can't affect SSD's. Shouldn't affect HDD's either. The ones I've torn apart are pretty well sealed.
