can a battery in parallel with a PSU work - same voltage to instantly boost current?
sam68
Joined Mar 2, 2017
41
Now, that is nice - thanks Alec.
The PSU will be 19 volts (laptop power supply) - will that change any of the values?
I assume, when using the battery pack to power the speaker, I would just unplug the above circuit output from the amp, and plug in the battery pack. That is the easiest.
Since I'm a novice at this, what value do I need for the M1 (P-Mosfet) = 20PCS New AO4606 AO 4606 SI4606 MT4606 N+P MOSFET SOP-8 ($1.05). I will just be soldering the circuit raw, so do I need special ends that will accept the solder?
and D1 MBR735 = 2 x MBR735G MBR735 Schottky Barrier Diode 35V 7.5A = OK?
Alec_t
Joined Sep 17, 2013
15,167
No.
That's one way. Or the battery pack could simply connect in place of the PSU.
I wouldn't use that one. Go for something beefier (at least 10A rated), in a TO-220 package rather than a tiny SOP-8 package.
I'm not sure how effective this circuit or any of the other proposed current-boosting arrangements discussed in the previous posts will be in practice. A lot will depend on how the PSU responds to sudden demands for current beyond its capabilities. Will it shut down, go into current-limiting mode, or what? Also, sharing the current load between two sources will be affected by their equivalent series resistances; the one with the lower resistance will tend to provide the greater current.
