Completed Project Can a 12V automotive fuse be used in a 6V circuit?
Rahulk70
Joined Dec 16, 2016
538
I have a 6V circuit that draws around 4.2A. The 6V power supply is a Lead Acid Battery. So for safety reasons I want to protect the circuit with an external fuse block. Can I use a 12V 5A fuse? Or is it the total power of the circuit that matters(here in this case around 26 watts)? If that is the case then I'll need a 12V 3A fuse I guess?
Alec_t
Joined Sep 17, 2013
15,112
It's the current that's important here. So the 5A fuse is the one to use. A 3A fuse would blow almost immediately with a 4.2A current.
#12
Joined Nov 30, 2010
18,224
So you mean the watts of the fuse as well as the circuit should match?
That's like saying the doors in my house are 78 inches tall so only people that are 6'6" wide should enter.
The voltage rating on a fuse is the highest voltage it can stop when necessary.
The fuse current rating is the highest current it can allow.
The wattage, as the current multiplied by the voltage rating, is useless.
You can't use a 12 volt fuse rated at 30 amps on a 120 volt circuit which uses 3 amps and you can't use a 120 volt fuse rated at 3 amps on a 12 volt circuit that uses 30 amps.
Each limit is separate and must be considered separately.
MaxHeadRoom
Joined Jul 18, 2013
30,609
Usually the maximum I/V rating should be observed, for automotive fuses they are intended for use on low voltage DC, one reason is the exposed test pad on the top.
The popular 3Ag style of glass fuse can be used up to 250v.
See the Littlefuse site and others for details.
http://www.littelfuse.com/products/fuses/cartridge-fuses/3ab_3ag-6_3x32mm-fuses/312.aspx
Once you get into higher voltages, the insulation and sweep through rate is important at high voltage.
Max.
38,435
No. Watts has nothing to do with it.
The fuse voltage rating is the highest circuit voltage that should be used with that fuse.
If you use a fuse at higher than its voltage rating, it may arc over and not properly clear the circuit when its current rating is exceeded.
The fuse current rating is not affected by the voltage.
Kermit2
Joined Feb 5, 2010
4,162
Heat is created in a resistance when current flows.
The heat loss is also known as I(eye)squaredR
Meaning current, represented by the "I" in ohms law, in amperes is squared and then multiplied by the resistance value, represented by R, in ohms.
All that because this stupid phone can't put in superscript and I'm to lazy to seek another way.
So voltage has little to do with the actual physical red hot, melting apart operation and more to do with the physical structure of the fuse itself.
There's a voltage rating of the fuse BECAUSE, at below that rating, there is a possibility that the circuit can complete through air or an arc inside the fuse. So a 250 V rated fuse is good for any operating VOLTAGE below 250 V. The automotive fuses are usually rated for 32 V or so.
There are lots of other parameters such as interrupting capacity and delay. For that information, you have to look at the datasheets.
The smallest cross sectional area for the most part determines the current rating.
Rahulk70
Joined Dec 16, 2016
538
So I guess its okay to use a 12V fuse in my circuit. I'm planning to use a 7.5A fuse since 5A is very close to 4.2A. I'll just try short-circuiting a 7.5A fuse and see if it blows.
Rahulk70
Joined Dec 16, 2016
538
Guys! So I tried the short-circuit destructive testing with 3A,5A,7.5A,10A,15A auto blade fuses & a 20A cartridge fuse. I didn't think a 6V 4.5Ah battery could give such large currents on short-circuits.Checked the manufacturer datasheet just now to get an idea and its capable of 50A for 5 secs and around 150+Amps on short circuit. All the fuses where like BAAM:D!! I couldn't see the the smaller ones melt except the 15A was like glowing red hot and it deformed the plastic before breaking the link. While the 20A glass cartridge fuses also blew with a blue colored flash in the center and the wire inside split into two.
Rahulk70
Joined Dec 16, 2016
538
Oh forgot to ask this. In the above circuit the continuous current draw (4.2A) is directly with a universal 3 position 3 wire ignition key switch. The switch model is Minda D-08. But I couldn't find any datasheet or specs about it(its almost 2 decades old:) but an unused one). So is this setup fine or should I run the device through a relay? Can the ignition switch handle this current continuously?
Thanks.
