Calculating Voltage
Polipker
Joined May 11, 2022
9
Hi, I would need some help about how to calculate voltage in the marked led. Thx a lot!
Papabravo
Joined Feb 24, 2006
22,111
We don't generally calculate the voltage across an LED. We look the manufacturer's datasheet and based on the current through the LED we estimate the forward voltage drop. The forward voltage drop of an LED that is on won't change much as the current varies over a wide range.
Alec_t
Joined Sep 17, 2013
15,156
According to the schematic the series combination of the LED and the 1k resistor has only 903mV across it. The voltage across the LED (not in the LED) will be 903mV less the voltage drop across that resistor. Now you just need to find the current tthrough that resistor and use Ohm's Law.
Polipker
Joined May 11, 2022
9
Thanks you mate!
Audioguru again
Joined Oct 21, 2019
6,826
An LED will not conduct with such a low voltage as 903mV.
The transistor driving that LED shows a current of 4.53mA then maybe the voltmeter has a very low resistance and is using most of the transistor current.
35,184
An LED is a PN junction semiconductor device. This has an exponential I-V relationship.
The slope of the I-V curves represent the reciprocal of the resistance, i.e. 1/R.
Hence you can see that when Vf is below 1V the slope is almost zero, thus the resistance is very high.
With 903mV bias voltage on the LED and 1kΩ series resistor, almost all of the 903mV will be across the LED.
