Calculating losses and Mosfet selection for Single Phase Inverter
Deleted member 440916
Joined Dec 31, 1969
Usually switching losses are a high proportion of the total so modelling is essential.
As for device selection, try voltage, current, RDSON & package :)
38,814
Fast switching is essential to minimize switching losses, since it's during the transition time between on/off that much of the loss typically occurs.
To minimize that you need to drive the high gate capacitance with high current drive.
Another loss is the through the ON-resistance of the MOSFET.
Thus you want a MOSFET with a low ON-resistance along with a relatively low gate charge to make it easier to drive and switch rapidly.
Joined Dec 31, 1969
.Thus you want a MOSFET with a low ON-resistance along with a relatively low gate charge to make it easier to drive and switch rapidly.
Unfortunately both dependent upon die area in opposite directions, I hate reality, where is my perfect power mosfet :) (Actually in modelling I often use a voltage controlled switch)!
