Calculating capacitors
Ian0
Joined Aug 7, 2020
13,249
Need to explain that one!
Max.
Ripple voltage is approximately equal to It/C.
That works out to 10V.
That‘s a lot of ripple for a 12V supply, about 80%, not much better than if you hadn’t bothered with the capacitor at all.
But for a 100V 1A supply with 1000uF, it’s still 10V ripple, and now it‘s only 10% which is quite usable.
note: one normally assumes that t=1/2f, but it is less than that due to the time spent charging the capacitors, which increases as the ripple gets bigger, but it is a very useful approximation.
Ian0
Joined Aug 7, 2020
13,249
OF COURSE! As long as there is an adequate source voltage provided a linear regulator will remove all ripple at frequencies below it's frequency response limit. So that is an additional option available. BUT it does require a large enough capacitor to keep the voltage at least 3 volts above the regulator output setting.
And how warm is that regulator getting?
