I found this paper to be useful. It says:
where N is the integer part of P, and 0≤ <1 is the fractional part.
I'm not a software/firmware guy so basically I'm asking for some help on how to code this equation in the microcontroller, like a pseudocode. Any other suggestion is welcome.
Paper: http://www.eletrica.ufpr.br/edu/artigos/CIL22-012_final_gerson.pdf
So in my case for one cycle, I can't have an integer N that matches both 50 and 60 Hz and possible fluctuations. In the microcontroller, the plan I have is to set an ADC triggered by a timer for a fixed sampling frequency. I can also use DMA or double buffer approach if needed. The formula for RMS proposed in the paper isDue the characteristics of AC energy, voltage and current waveforms mean are zero; however, during abnormal operation fluctuations may occur or oftentimes the offset error introduced by transducers must be accounted for the correct characterization of the energy. These calculations are performed with a digital processing, using sequential samples with sample frequency equal to N times the AC frequency, nominally 60 Hz or 50 Hz. If the value N exactly matches the ratio between sample frequency fs = 1/Ts and AC frequency f = 1/T, there are only quantization errors due to finite length of bit number of samples. If, however, the ratio fs/f is not an integer value, what occurs most of the cases, more errors are introduced (Mesrobian et al., 1991).
