Calculate required capacitance and ESR required for a highly transient pusled load
SiCEngineer
Joined May 22, 2019
207
I am trying to determine the amount of output capacitance that is required by my power supply to ensure the transient response demands are met and controller stability is ensured.
I have designed a buck current-fed push-pull converter that generates a max output voltage of 6kV for a radar transmittter. But I am stuck at this point. I have designed an LC output filter to get the voltage ripple very low, but cannot find a reliable source that lets me know how to calculate the required capacitor bank value and combined ESR that ensure I stay within the maximum and minimum voltages of +/- 5V respectively. I have seen a document before that did this but I cannot seem to locate it anymore.
The current transitions from full load to 0A at rates anywhere from 100Hz to 100kHz at duty cycles of 50% and 1% respectively, as an example.
Does anyone know the correct procedure for calculating the C and ESR required to meet the transient demands.
Thanks in advance
