Calculate Cable thickness depending upon current
Vindhyachal Takniki
Joined Nov 3, 2014
598
1. I have bought a low cost ac-dc charger from China. It is from 220Vac/50Hz to 54.6Vdc/20V charger.
It dont have any manual or wiring diagram with it. It has five connections: Line,Netrual & earth on input. On output it has thick terminals for V+ & Ground.
2. At output 54.6Vdc/20A, wattage is 1092W. How to calculate what is the exact wire & its size I should use. I have to charge a battery, so have to make red & black wire with clips myself. But what wire size(AWG) should I buy.
3. Similarly at input, it is 220Vac/50hz. Output is 1092W, consider charger is 75% efficient (though there is no manual, I am cosindering this as worst case), power at input will be: 1092W/0.75 = 1456W.
For this which wire should I use?
Is there any calculator to calculate?
1. For dc, I found below:
http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
2. For ac & dc
http://www.powerstream.com/Wire_Size.htm
But this is not for exact dc. need to select AWG first.
Got idea from these two. But any more info on this also?
#12
Joined Nov 30, 2010
18,224
You found calculators for wire inside a steel cabinet. Is that where you will permanently install this machine?
JUNELER
Joined Jul 13, 2015
183
What type and size of battery you will charge. And where it is use for...
Anyway you for ac line input wire you can use size no.16 while on dc side size 20 or 22.
Try it without any calculation
Kermit2
Joined Feb 5, 2010
4,162
You use a chart of resistance and the max. current you have.
Get ohms per foot and estimate resistance from the length you choose and multiply that by amps. The answer is the voltage drop you will have with that wire size. You want less than 10% of rated voltage. 5.46 volts is to much in your case.
Example
If your cables are .05 ohms each. Then resistance is .10 ohms.
.1 ohms times 20 amps is 2 volts dropped. (1 volt across each cable)
hp1729
Joined Nov 23, 2015
2,304
2. For ac & dc
You really need to make a calculation? Go to Ace Hardware and ask your "helpful hardware girl".
How precise a calculation can you make? How many options are there?
DC aside, 14 AWG, TW or THHW copper, not aluminum. What is available where the OP is? Calculations aside, what can he get where he is at?
MrSoftware
Joined Oct 29, 2013
2,273
