Calculate Battery Voltage Reducement
moeen_saberi
Joined Nov 20, 2018
Hello and thanks for great site!
i have a 6 volts,12ah lead acid battery which it's state of charge(soc) at 100% is 6.37 volts
in other hand, i have a circuit that runs with 5 volts and it's current consumption is 100ma
by connecting this circuit to the battery, how can i calculate after one hour, how much battery voltage will be ?
any help would be greatly appreciated
ericgibbs
Joined Jan 29, 2010
21,541
hi ms,
Welcome to AAC
The usual way is to check the graphs for that type of battery.
This image is for a 12v SLA, just divide the Voltage by 2.
The plots are for a battery in new/good condition.
E
BTW: you should not connect a 6V bty directly to a 5v circuit.
moeen_saberi
Joined Nov 20, 2018
Thank you for your reply,
yes, i use diodes or regulator for keeping circuit voltage on 5 volts
now i have another question
is it right to say that due to circuit current consumption value(100ma), after one hour battery current will be 11.99?(12-0.1)?
and if this is true, can we divide 11.99 to 12, (11.99/12=99%) to get battery charge percent after one hour?
