c++ programming pic microcontroller
alimash
Joined Oct 12, 2016
67
is there a website that teach how to program pic micro using c++ language?
i am familiar with miKro c(c programming) and and assembly language
Why? Abstraction is great but abstraction (like abstract art) can also mean hard to understand. In small constrained systems the real hardware has to be embraced. A skilled C engineer can easily handle the programming needs of a 8-16 bit small system with no OS, limited memory, small stacks and limited and/or strange von-Neuman or Harvard architectures. For 32-bit embedded systems with modern cpu architectures C++ might a sensible option.
CS programmers gone wild in an EE world is usually what happens when tools like C++ are used in projects that should be a Procedural programming task.
alimash
Joined Oct 12, 2016
67
i have a c++ programs written for a raspberry pi (arm processor) and i need to understand it,
i did not program a micro using c++ before and i am not familiar with arm architecture
i figure that maybe using c++ with a familiar architecture (for me) like microship pic is a good start before beginning with arm
regards
WBahn
Joined Mar 31, 2012
32,829
How about just learning the basics of C++ first? Then you will be in a good position to deal with the ARM/Rpi specific calls in the code you are looking at.
