C# program and libraries for modbus rtu rs485.
Saviour Muscat
Joined Sep 19, 2014
187
Hello helpers,
Hope I am in the right place
Currently, I am trying to interface PLC with Modbus RTU RS485 and my mentor suggested me to find c# program and libraries that are able to communicate from PC to PLC and then use them to generate log/text files for the relevant Modbus registers. I am a newbie in c# programming then I followed basic tutorials on youtube to have a general idea, I downloaded and installed visual studio 2019 and I ran some programs found on google search and GitHub but with no success, sometimes they freeze or they are too complex to run and a little bit hard to understand. Please could someone advise/ suggest, books, articles, source code, libraries to accomplish my task?
Thank you in advance for your kind help,
SM
Saviour Muscat
Joined Sep 19, 2014
187
Hello members,
From the last post, I found a library called EasyModbus that I was able to run on C# with minimal effort. I accomplished to write coil 0 and to write holding register through Modbus but when I tried to read coil 0, I found some difficulty.
I did a tentative program on c# as follows
1 when button one is pressed coil 0 toggles to On.(works)
2 when button two is pressed coil 0 toggles to Off.(works)
3 when input 0.0 of the plc is on is it supposed to show yellow square and when it is Off a red square.(don,t work and I tried several times).
Kindly could someone indicate/advise an amendment of the program when reading the input 0.0 of the plc as explained in the third bullet, please?
Please see the attached program and tentative GUI
C#:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using EasyModbus;
using System.Windows.Forms;
namespace plctry
    public partial class Form1 : Form
        ModbusClient modbusClient;
        public Form1()
            InitializeComponent();
            ON.Visible = true; //yellow
            OFF.Visible = true;//red
            modbusClient = new ModbusClient("COM5");//communication settings
            modbusClient.UnitIdentifier = 1;
            modbusClient.Baudrate = 19200;
            modbusClient.Parity = System.IO.Ports.Parity.None;
            modbusClient.StopBits = System.IO.Ports.StopBits.One;
            modbusClient.Connect();
            var value = modbusClient.ReadCoils(0, 1);// read coil zero and if it is true change color yellow else change collor to red
            if (value[0] == true)
                ON.Visible = true;
                OFF.Visible = false;
            else
                ON.Visible = false;
                OFF.Visible = true;
        private void button1_Click(object sender, EventArgs e)
            modbusClient.WriteSingleCoil(0, true);//toggle coil zero to on
            //modbusClient.WriteSingleRegister(19,123);
        private void button2_Click(object sender, EventArgs e)
           //modbusClient.WriteSingleRegister(19, 456);
            modbusClient.WriteSingleCoil(0, false);// togglr coil zero to off
Thank You
SM
ApacheKid
Joined Jan 12, 2015
1,762
I'm not quite sure what question your asking here, but I did notice this is too wordy:
Code:
                ON.Visible = true;
            else
                ON.Visible = false;
                OFF.Visible = true;
This is shorter:
Code:
   ON.Visible = value[0];
   OFF.Visible = !value[0];
