Hi A,Hex for which processor?
Hi A,The hex code for an arduino will not work on a PIC.
Your best hope is to understand what the arduino code is doing and write the function in your basic. That will not be easy if you don't know C or the way arduino code works.
What AI did you use?I used AI to convert it,
Hi A,What AI did you use?
I haven't come across anything that could do this.
