Buying Oscilloscope Probes
Sparky49
Joined Jul 16, 2011
833
Hi everyone.
I have just bought a new (old) digital oscilloscope from Ebay. Should be arriving in a few days and I'm really excited, it's my first digital oscilloscope and it has a pretty decent bandwidth (400MHz).
Anyhow, until now, I have used the 'cheap' 15MHz probes from Ebay to do measurements, but with the higher frequencies I am planning on measuring I presume these will not be so suitable.
So, what do I need to look for in an oscilloscope probe? Googling hasn't provided many clues, reviews tend to be for the cheapest, low bandwidth probes on the market. Bandwidth is presumably a key characteristic, but surely there must be differences between the £50 and £500 versions? (I'm not buying a £500 probe lol).
Many thanks for your time.
Sparky
Dr.killjoy
Joined Apr 28, 2013
1,196
Hi everyone.
Sparky
I use Uni-T probes from ebay and they never gave me any problems at all.. I would find a set of probes that have the needed comp range for your scope and you should be good .. Unless you want to find some used probes and try them ....
Lestraveled
Joined May 19, 2014
1,946
I have a 500 MHz LeCroy scope and I use the inexpensive Tektronix copies for normal use (<100Mhz) and one or two high end probe for >100 Mhz. EBay EBay.
Sparky49
Joined Jul 16, 2011
833
Yeah, that's the plan I was aiming for.
But what sets the higher end probes apart from one another? I can get a new 450MHz probe from one place for £50, and a 300MHz probe from another for £100. What else is there to consider?
Dr.killjoy
Joined Apr 28, 2013
1,196
Well the age old question ... Do you really have a use for them at the high of a frequency?¿? Are you going to build something that really need all that bandwith or can you just use 100 MHz or slightly higher and be fine ???
Sparky49
Joined Jul 16, 2011
833
"Do you really have a use for them at the high of a frequency"
Yes, hence why I am asking what other characteristics of probes set them apart from one another.
tindel
Joined Sep 16, 2012
939
I've always been curious if you can really get 400MHz bandwidth with passive probes... I just haven't had time to test it. I have some passive probes at work that claim 500MHz... which I think is phooey. I'd recommend active probes, with the circuitry near the tip to obtain the lowest parasitic capacitance possible, but active probes are expensive. and as always... keep your probe leads as short as possible to minimize inductance, as well.
38,704
Cost is usually (but no always) related to the quality and durability of the probes. For high frequency you want one with the lowest 10X probe capacitance since even a small capacitance provides a significant load at 500MHz. For example 10pF has an impedance of about 40 ohms at 400MHz.
33,084
Is it possible that the first are passive and the second are active?
tggzzz
Joined Mar 14, 2015
4
Well, £500 for a scope probe is pretty cheap - some are >£10000!
Fortunately there is one type of very high performance probe that is relatively easy to make at home - a "low impedance Z0" probe. The name is a misnomer, since it can have an impedance higher than a standard 10:1 probe.
See the references at https://entertaininghacks.wordpress.com/library-2/scope-probe-reference-material/ for when to use different types of probe, and how to make your own probe.
Esposito
Joined Apr 21, 2015
4
The original probes supplied with the 2235 were Tek P6109's. However a P6121 or P6122 will also match up. And I've used the older modular Tek P6105 probes also. The input is 1 megohm w/20pF capacitance. A 1 megohm input is very standard and most aftermarket probes will work with this input.
These probes are all 10X type. Meaning they reduce the signal by a factor of 10 to provide low circuit loading and maintain good bandwidth up to 100mhz, which is the 3dB point of the scope. (50% down) For all but the most critical pulse analysis, low cost aftermarket probes will be ok. They will work but may lack the durability of Tek probes.
All 10X probes must be compensated (adjusted) to the scope's input by looking at the scope's square wave calibrator output and adjusting for a sharp corner without overshoot or undershoot. This is usually done with a small screwdriver adjustment at the probe's input connector, or sometimes by turning the probe's body.
tggzzz
Joined Mar 14, 2015
4
Not really. At 100MHz a 15pF tip capacitance has a load of only 107 ohms.
A "low impedance Z0 probe" has a load of 500ohms or 1000ohms!
3dB = 50% power reduction = 30% voltage reduction (remember dB = 20log10(v1/v2) )
RichardO
Joined May 4, 2013
2,270
The simple answer is to buy the best probe you can afford -- your measurement can _never_ be better than the probe. I once paid more for probes to go with a used scope than I paid for the scope itself. I have never regretted it.
Also remember that the system risetime is equal to the square root of the sum of the squares of the risetime of the scope and the probe:
System_risetime = sqrt (scope_risetime ^2 + probe_risetime ^2).
Himanshoo
Joined Apr 3, 2015
265
Hi everyone.
Sparky
does normal bnc connector work at high frequencies?
tggzzz
Joined Mar 14, 2015
4
Yes; the Keysight N2874 is a 1.5GHz probe with BNC connectors: http://www.keysight.com/en/pd-1661742-pn-N2874A/passive-probe-101-15-ghz-13-m?cc=GB&lc=eng At these frequencies, the BNC connector is not the major problem.
For more information on probes, see https://entertaininghacks.wordpress.com/library-2/scope-probe-reference-material/
For a homebrew accessory that improves the signal integrity visible with standard 10:1 probes in the hundreds of MHz range, see https://entertaininghacks.wordpress.com/2015/04/23/scope-probe-accessory-improves-signal-fidelity/
