Good evening,
I intend to repair if possible the PCB from a Sakura SS3630 6A 12V battery charger, else I will make a new control circuit.
The present PCB is very simple with 4 x 6A10 diodes and a small driver circuit for the 3 LED panel lights - 2 x 4.6K resistors and a little loop with a 75 ohm in series with a C13ST (13V) Zener diode, tapped into the PCB as per the pictures. These all test out fine and the transformer is also OK.
The burned out, and i do mean burned, component is in series with the positive DC output rail and as far as could see was a two leg 10mm x 10mm "bit" was was some type of (don't laugh) saftey device. I would have expected a fuse but this is, was, something else any ideas ?
Comments or advice appreciated
TC
TC
