Building Guitar Amp From Panasonic
Jsprite7660
Joined Jan 9, 2024
56
Hey All,
I modded this Panasonic Radio into a guitar amp by wiring the guitar signal to the center tap of the volume potentiometer. I want to get rid of the other stages of the radio and only use the audio amplifier stages as an amp.
I drew out the portion of the schematic that I am going to isolate, and I was wondering if it would work as is?
35,171
My suggestion would be, if you want to build a transistor amplifier for a guitar, there are easier and better ways to do this.
You will be very disappointed with the amplifier in the radio. Leave the radio alone as is.
Jsprite7660
Joined Jan 9, 2024
56
The whole reason why I'm doing this is because I love the way this sounds.
BobTPH
Joined Jun 5, 2013
11,647
The Question is why? You can buy a powerful class D amp for just a few dollars. Add a an old laptop supply and it costs way less than a mains isolation transformer with far more power and performance. You would need a preamp, but these can be built for practically nothing.
Jsprite7660
Joined Jan 9, 2024
56
Which question?
LowQCab
Joined Nov 6, 2012
5,102
The Speaker(s) and the Speaker-Cabinet(s) are what determines the "sound" not the Amplifier.
I also vote for the Digital-Amp and LapTop-Power-Supply.
You can use any High-Fidelity-Speaker if You are also using a Guitar-Oriented-DSP-Program
and get tons of phenomenal Guitar-Tones, for CHEAP.
( DSP = Digital-Signal-Processor )
Using a Speaker specifically designed for a Guitar-Amp limits the types of "Tones" You can produce
and will result in very weird and uneven sound-dispersion-properties from the Cabinet,
so why handicap yourself right from the start ?
Go to a Pawn-Shop and get a complete Home-Stereo for cheap, then work on the DSP part.
Many DSP's will also produce a Stereo-Output.
Here's an excellent Guitar-DSP from Fender ...........
28,251
The comments about safety are certainly correct! And that is a serious issue. Now liking the way it sounds is a separate concern.
There are several choices as to the way to remove that shock hazard. An isolation transformer in the mains power feed is both simple and quite expensive. A much less costly approach will be a very small transformer at the input side. Finding a transformer like that new will not be too difficult, but a used one from a small radio will be much cheaper. The exact transformer ratio is not super critical , but probably lower that ten to one, or one to ten, will be the best choice..
And that transformer will be small enough to mount inside the radio enclosure.
One more thing: Guitar amplifiers would seldom be described as "Hi Fi" systems. So using a standard "HiFi" amplifier will usually require adding quite a bit to get that same "sound."
Jsprite7660
Joined Jan 9, 2024
56
Why you want to use the amp from an old radio that is going to be terrible compared with current day technology that is super cheap.
Yeah I forgot about all the new technology and I just randomly started working on an old radio simply because I forgot that it's 2024
Jsprite7660
Joined Jan 9, 2024
56
Mr Bill thank you for this! I'm going to go this route. This is what I was asking about in the first place. Thank you
28,251
The transformer does not even need to have a power handling rating, it can be the size of a microphone transformer. I am guessing that the guitar is not a bass guitar. The low frequency might be a problem.
I have seen some transformers made for microphone inputs. They connect an XLR connector cord to a 1/4 inch plug. But I have not checked the ones that I have to see if they are isolated or not.
