How many Hours will a 4. Dabble A Battery Pack lest with the LED Running at 80 mA?
So it depends on how much current you draw. You don't have to run the LED at 80mA, you can run it more in the suggested range of 65 to 75mA. BUT you don't have to run it at those amperages either. You could run it as low as you like. Whatever gives you the amount of light you want.I saw that too. Perhaps a rethink on your entire design may be appropriate.In the datasheet that @LesJones refered to, I noticed that the beam angle is very narrow.
The lower you run at the longer it will run for. If you run at 80mA (max) then compare it to running at 40mA you'll find it lasts twice as long.You don't have to run the LED at 80mA, you can run it more in the suggested range of 65 to 75mA. BUT you don't have to run it at those amperages either. You could run it as low as you like. Whatever gives you the amount of light you want.
LEDs are not voltage driven; they are current driven. So the statement “you will not get the voltage you need” doesn’t make sense. You need the current and LEDs operate on a wide range of currents.If you up the Resistance you will not get the Voltage you need.
It's worth repeating. Especially if the TS is not getting the message.LED's are "Current Driven".
Do you understand the meaning of the viewing angle? If you have a 10° viewing angle and you are 10 ft away, positioned so it looks maximally bright. Then you move 1 foot to the left or right, you are outside the viewing angle, and the brightness will be greatly reduced.Rated 3.4 Volts at 20 mA.
It has a 10 Viewing Angle.
